Trying to get the heaviest thrash tone I can!!5153 el34 100w
I’ve had this song close to being finished for awhile. But I know I truly never dived in and questioned every section, every beat that I got “lazy” with. As a lot of times when I’m writing, I’m writing the beats with it, but they don’t get as much initial scrutiny as the riffs of course. And then when all is said and done I go back and fine tune everything. I really hadn’t done that for this song since it was pretty close straight away. But it was also laziness. Anyway, I fine tuned the beats and the structure.
I also decided instead of sorta getting more of style’izd (lol) thrash tone. Meaning a bit more bite and chunk and less gain on some occasions, I said tuck all that, let’s just do my tone I use for death metal, for example. Which is more gain!!! More thicker and just a little rounder without losing much tightness. So this is the 5153 el34 on the red channel, with gain on like 8. Which the great thing about these amps is the clarity is there almost the entire sweep. It just thickens up with more gain applied. And even then it never gets too out of control..
Also brought out the Beta57 which I used to use almost exclusively in years past. I NEVER used the regular 57. And it’s been sitting for awhile. So I paired the beta 57 with the Sennheiser 421. Definitely feel this is a good representation of the tone!
https://app.box.com/s/241tny7zfnd90g7x53crfqh2xzzrv78y
Alternate Red clip with EMGs https://app.box.com/s/c3ang2r6unczzhz0fr0phl10t3uvdbjk
Re: Trying to get the heaviest thrash tone I can!!5153 el34
yeah there's definitely a lot of clarity for the amount of gain involved, since 8 on the red channel is truly a metric ton of gain hahaha... but it sounds good and it's definitely a good fit for the song!
GuitarBilly wrote:yeah there's definitely a lot of clarity for the amount of gain involved, since 8 on the red channel is truly a metric ton of gain hahaha... but it sounds good and it's definitely a good fit for the song!
Thanks man! And honestly it’s one of those channels that it really doesn’t get more distorted the higher it gets, it just fills out a bit. It’s pretty much max gain at like noon. Anything above just fills out some of the spectrum. And to some degree I find it a bit easier to dial in the eq with the gain higher . On the red channel that is. Blue channel is a bit more balanced overall so it’s not as picky when it comes to eq settings
- Mike Oxhuge
Sounds fucking amazing! Great tune and riffing too! Might be my favorite tone from you yet!
Peavey XXX Head
Henning Bottle Rocket Preamp
Carvin MTS3212 Combo
80's Washburn Scavenger Bass
Boss GT1000
Boss GT1000
EndTime wrote:GuitarBilly wrote:yeah there's definitely a lot of clarity for the amount of gain involved, since 8 on the red channel is truly a metric ton of gain hahaha... but it sounds good and it's definitely a good fit for the song!
Yeah that's a good observation about the evh red channel.
Mike Oxhuge wrote:Sounds fucking amazing! Great tune and riffing too! Might be my favorite tone from you yet!
Big thanks man!! And yeah it’s fresh, but I love the tone too! It’s honestly what I was shooting for when I set out to do this. And that isn’t always a guarentee! Hah. And since my ears were kid a fried after recording I wasn’t into the initial mix but when I came back the next day I knew it sounded huge, and actually the main mic here is the 421. Prolly 10db louder than the beta 57. But as soon as I put that beta 57 in the mix it really does add that grit and snarl. But the overall tone just has this growl in the low end which this amp 100% has in spades I just haven’t always captured it like this time
Agreed, this is balls out!
Damn! Gain on 8, eh! I never would've even tried to record it that high haha.
EVH
Mesa
Bauer
Guiterrorist
Pakistani Right Hand of Doom
Pesobag
Mesa
Bauer
Guiterrorist
Pesobag
VTM wrote:Mike Oxhuge wrote:Sounds fucking amazing! Great tune and riffing too! Might be my favorite tone from you yet!
Thanks dude
NinjaRaf wrote:Damn! Gain on 8, eh! I never would've even tried to record it that high haha.
You left some tone on the table! I ran it at 7 fairly often anyway. . Again, it’s just the shape of the tone when the settings get higher.. It’s not more gain. It takes on a bit more of a PV gain structure the higher it goes. Thicker lower mids and the compression. . For the most part it’s usable til almost 10. Not quite as it starts being too much when maxed but it should be designed to be basically usable most of the sweep and then only on “10” is it too much.. From a design standpoint that’s what makes most sense to me and I think that was likely their intent.
But also I saw EVh himself used to run the red channel gain pretty high and I even saw the Gojira dude use the el34 and his gain was on 8. It’s good to experiment and know every tone in the amp.
Yeah, I mean I definitely played with the gain that high, but like you said, it changes the response, and I didn't like what that change was, so I never would've been like...oh I like this lemme record it.
EVH
Mesa
Bauer
Guiterrorist
Pesobag
Mesa
Bauer
Guiterrorist
Pesobag
i agree, mix is perfect
RaceU4her wrote:Mike Oxhuge wrote:Sounds fucking amazing! Great tune and riffing too! Might be my favorite tone from you yet!
Thanks dude! Found sumthin in there I think I could repeat if needed! Cause the red channel can be a little finicky to record, some days I’m like, what sounds like this? Other days I can hear sumthin inherently I don’t like. Blue channel, has it all tho. If I just had a one channel amp, it’d be the blue of the el34 100 watt. Just cause it can get literally as heavy and distorted as the red and do more 80s style thrash plugged straight in. And even clean up with the volume on the guitar
I did one more clip with EMGs. And a single mic.. I dug up this EV n/d468 mic. I also used to use this quite often and it has a smoother midrange than other similar mics which I really liked.. I went thru 4 guitars or so and picked the one I thought sounded best. Ad it turned out to be the EMG 81 at 18votls
Sounds killer!!
Engl Retro 100
Engl Artist
Freidman 2x12
Bogner Helios 2x12
Solar V2.6AG
Ibanez RG521 Black (Fishman Tosins)
Ibanez RG521 Blue (Fishman Moderns)
Cort G300 pro (Fishman moderns)
BC Rich Warlock NJ (eddies)
EVH 5150 standard stealth black
Ibanez RG550 (Fluence modern)
Solar A2.6AG
BC Rich Gunslinger II Prophecy
Ibanez sca220B
Engl Artist
Freidman 2x12
Bogner Helios 2x12
Solar V2.6AG
Solar A2.6AG
Ibanez sca220B
Killzone wrote:Sounds killer!!
Hey man! Long time no see but thanks a bunch!!!
And because it’s prolly run it’s course I dug up the lewitt 440 mic I think it was. I remember initially thinking it went great with a 57 but not so much in its own. And it sounded great. So I had to do a version with just the Lewitt. I’ve been sitting with these all for a few days and I think this is actually my favorite!
Lewitt mic - https://app.box.com/s/34l2e6l9k6zllqdxq2ljqiks8n8ut6nl
Holy shit. This is unreal good.
Every part is energy on 11 and the whole thing fucks.
Bullshit platform!
The first EMG clip is my favorite of the bunch. Absolutely slammin'!
The Lewitt sounds good. I have one here I should try to record some tracks with it
Dave wrote:Holy shit. This is unreal good.
Thanks man! Honestly I wish to not always be “on 11” it’s just kinda what happens. But I’m actively trying to restrain some of that. And I write a LOT without this speed and aggression. My problem is I’m trying to shoehorn it into a more metal setting cause that’s the type of collaborators I have and really that other stuff needs sumthin else.
Anyway….. lol. Thanks again
VTM wrote:Bullshit platform!
Thanks too! The vocalist for this thru that name on it. Pretty sure it’s just a working title but who knows, maybe it’ll be the final one!
GuitarBilly wrote:The Lewitt sounds good. I have one here I should try to record some tracks with it
I didn’t really like it much at first except with a 57 and figured we’ll it’s at least good for that but this was it by itself. It has a bit more relaxed midrange than a 57 and WAY more low end. But it’s pretty clean the low end. I had to chop a bunch out but it’s still got good low end energy. Gonna keep playing around with it.
