OD Pedal for a Plexi
- maggotspawn
Looking for an OD for my 50 watt Plexi clone. Currently using a Klon clone. Looking for hard rock and metal tones.
Re: OD Pedal for a Plexi
For a boost?? SD-1, TS-9 and Klone are the main options ands I think every Marshall Player should own all 3 of them. A good 4th option is the Fulltone OCD. And the BB Preamp is a good choice too.
If you are planning to run the amp clean and use a pedal for your gain tones, I highly recommend the Carl Martin Plexitone. Or the Caline Englishman, which sounds identical. But I'd still get the Carl Martin just for the extra peace of mind with the build quality. And it's good to support the original designer, especially since the pedal is not outrageously expensive.
- maggotspawn
GuitarBilly wrote:For a boost?? SD-1, TS-9 and Klone are the main options ands I think every Marshall Player should own all 3 of them. A good 4th option is the Fulltone OCD. And the BB Preamp is a good choice too.
Thanks Billy. I have all of those except for the BB Preamp. Some experimenting to do.
- Mike Oxhuge
My best metal tones with Plexi and 800's involve triple boosting using an OCD 1.3 or the clone of it Billy talks about into a tubescreamer into a Boss EQ set to unity gain but with some flavor of 800hz and 1600hz boosted up. Don't be afraid to dial back the amp gain to just a bit over AC/DC levels with this setup.
Peavey XXX Head
Henning Bottle Rocket Preamp
Carvin MTS3212 Combo
80's Washburn Scavenger Bass
Boss GT1000
Boss GT1000
I used to run a Suhr Riot clone into a superbass and that shit slapped.
- maggotspawn
Thanks guys.
- TurboPablo
A Klone used as a clean boost would be my first choice. Plexis' don't need to much to achieve full on violent glory. If you need a bit more, bump the pedal gain up a bit.
- Mike Oxhuge
https://soundcloud.com/billy-coverdale/ ... al_sharing
This was an SM57 on a V30 JCM800 4104 (2204 in combo form).
Peavey XXX Head
Boss GT1000
Boss GT1000
- maggotspawn
TurboPablo wrote:A Klone used as a clean boost would be my first choice. Plexis' don't need to much to achieve full on violent glory. If you need a bit more, bump the pedal gain up a bit.
That would be the simplist solution.
- TurboPablo
maggotspawn wrote:TurboPablo wrote:A Klone used as a clean boost would be my first choice. Plexis' don't need to much to achieve full on violent glory. If you need a bit more, bump the pedal gain up a bit.
I assume you'll have the amp set loud and hairy.
- maggotspawn
TurboPablo wrote:maggotspawn wrote:TurboPablo wrote:A Klone used as a clean boost would be my first choice. Plexis' don't need to much to achieve full on violent glory. If you need a bit more, bump the pedal gain up a bit.
Loud with a touch of hair.
- Marc G
maggotspawn wrote:Looking for an OD for my 50 watt Plexi clone. Currently using a Klon clone. Looking for hard rock and metal tones.
I just got a Wampler Pinnacle and it takes my Plexi clone from a mild pushed sound on its own to full on brown sound.... I was not expecting it to be as good as it is
I have a Wampler Tumnus and OCD, different but got great options.
- colejustesen
So many options for you... Have you looked into the OCD? I think that would work great for you.
Amps
Hughes & Kettner Duotone
Laney GH100L
Peters Halo/Hydra
Rivera Chubster 40, M100
Rocktron Vendetta 100
VHT Pittbull 100/CL
Budda 2x12 (Jensen C12K2)
Rivera K412T (Eminence CV-75)
Splawn 2x12 (Fane M65)
Laney GH100L
Peters Halo/Hydra
VHT Pittbull 100/CL
- BroSlinger
- greatmutah
- Site Moderator
SD-1. Always my first choice.
Metropoulos Metro-Plex
Orange Rockerverb 50 MK III
Fender '76 Vibrolux Reverb
Marshall 1960A w/ Greenbacks
- maggotspawn
Thanks guys. I have an OCD clone and an SD-1, to try.
I'll try those first before I spend any $$$.
Zozobra wrote:I used to run a Suhr Riot clone into a superbass and that shit slapped.
Ong frfr? No cap?
I like the Kingtone Duellist so much I bought a second one for my new pedalboard. It has by far my favorite TS style pedal and I’ve tried just about all of them at this point. But what really surprised me was the Bluesbreaker side. I pretty much only use that side now unless I’m on a Strat neck pickup. Kingtone makes standalone versions now too. Highly recommend.
I’d go with a Digitech Metal Master.
Rampage wrote:I’d go with a Digitech Metal Master.
