Recorded some guitars with the ToneX pedal
Re: Recorded some guitars with the ToneX pedal
Honestly, the way everything sounded in the mix.......your guitar was chunky, gritty, nice top end, and that fullness that had a spank.......I don't know......I thought your rhythm tone was awesome and felt the same with the solo.
How did it feel to you when you heard it back?
*edit edit* Your tone reminded me of an early Ratt and Kingdom Come feel. Both of which I admire
I'm not sure what I think. It sounds good overall but I may be hearing some things too.
That's why I want to get some external opinions...
- Mike Oxhuge
Sounds very similar to The Cult Electric tones. Pretty damn good to me.
Peavey XXX Head
Henning Bottle Rocket Preamp
Carvin MTS3212 Combo
80's Washburn Scavenger Bass
Boss GT1000
Boss GT1000
- eyeball987
Sounds good to me.
Sounded just as good as any pro recording of the genre.... and Kimmy ROCKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks!!! I am going to play not with it. I think the tone is good but it was a bit harder than usual to get it to sit in the mix. And also harder to mix the vocals with the rest of the track too. Which is similar to what I usually hear with modeling on live mixes.
So I'm not fully sold on it just yet.
I'll make another mix tomorrow with amps for comparison.
- madrigal77
Honestly if you hadn’t said so I never would have known it’s not real amps.
ESP MX-2 White
ESP Eclipse II Vintage Black
LTD EC-1000T CTM Violet Shadow
Ibanez Acoustic: V300CW
Fractal FM3 MKII Turbo
Laney LFR-212
ESP MX-2 White
Laney LFR-212
- MacaroniSalad
Listening on AirPods, it doesn't have the clarity that I think you would get out of a real amp do that same sort of riffing in A. It has a bit of a "digital smear" in the A, D and G strings when they are played together.
The sound during the solo sounds "better" I think because the signal isn't stepping on itself with the single notes the same as it does on a full chord.
MacaroniSalad wrote:Listening on AirPods, it doesn't have the clarity that I think you would get out of a real amp do that same sort of riffing in A. It has a bit of a "digital smear" in the A, D and G strings when they are played together.
A-ha!!!!! Yeah I hear that too.
- MacaroniSalad
I might be crazy, but I feel like I've heard the same thing since back in the days of the Pod XT. Like you've said before, I wish I DIDN'T hear that, but I do, and I can't unhear it. And I heard it when I briefly had an Axe FX too, so I'm not terribly eager to jump back into modelling after that.
