Swapping valves
Swapping valves
I got some vintage valves from 60s and 70s. Can I just swap out the existing valves out of my champ 600 super champ xd or sonzera 20 (provided of course they are the same valve for example 6l6) or is there more to it ? Thanks all
Re: Swapping valves
Also is it only the pre amp valves that affect the sound? That seems to be 12ax7 on the champ 600 and sonzera 20.
Re: Swapping valves
For power tubes, you need to bias them. Easiest way would be with a bias probe.
The preamp tubes can be swapped out.
As for which tubes affect the tone the most, preamp tubes are easier to notice. Power tubes have a more subtle impact unless you are cranking the amp into power amp overdrive.
- greatmutah
- Site Moderator
Re: Swapping valves
GuitarBilly wrote:For power tubes, you need to bias them. Easiest way would be with a bias probe.
This.
Metropoulos Metro-Plex
Orange Rockerverb 50 MK III
Fender '76 Vibrolux Reverb
Marshall 1960A w/ Greenbacks
