Marshall 1936 2x12 mono input does not work
- boris the blade
I can't believe I never noticed this before, but the mono input does not work. only one speaker works, and if i use the other jack then only the other speaker works. bad jack plate or something? I compared the wiring to other 1936 cabs and it seems to be wired up just fine.
any ideas? thx
any ideas? thx
Re: Marshall 1936 2x12 mono input does not work
try cleaning the jacks? are they those plastic ones that marshall likes to use?
- Heath
The mono jack on these is a switching jack and they are prone to failure. As said above, cleaning is the first step, and replacing the jack is the second. It should take care of your issue though. The other option is to rewire the cab to mono without the switching jack.
Xotic XSC-1
PRS CE24
Sterling JP150
Wolfgang partscaster
PRS MT15
Laney GH30r 1x12
PRS CE24
Sterling JP150
PRS MT15
Laney GH30r 1x12
These Marshall jackplates are not reliable so wiring in mono is definitely But if you want to keep the switching, Mojotone makes a drop in replacement switch that is much better quality.
- boris the blade
trey85stang2 wrote:try cleaning the jacks? are they those plastic ones that marshall likes to use?
yeah its the plastic ones. Use Deoxit?
Heath wrote:The mono jack on these is a switching jack and they are prone to failure. As said above, cleaning is the first step, and replacing the jack is the second. It should take care of your issue though. The other option is to rewire the cab to mono without the switching jack.
I did read someone suggesting to wire it to mono, just desolder the wires from one jack then solder to the other jack, matching the wire colors?
- boris the blade
GuitarBilly wrote:These Marshall jackplates are not reliable so wiring in mono is definitely But if you want to keep the switching, Mojotone makes a drop in replacement switch that is much better quality.
ok thanks! I'll check the mojotone site, or just rewire it.
boris the blade wrote:trey85stang2 wrote:try cleaning the jacks? are they those plastic ones that marshall likes to use?
yeah its the plastic ones. Use Deoxit?Heath wrote:The mono jack on these is a switching jack and they are prone to failure. As said above, cleaning is the first step, and replacing the jack is the second. It should take care of your issue though. The other option is to rewire the cab to mono without the switching jack.
No
Follow this diagram:
- boris the blade
GuitarBilly wrote:boris the blade wrote:trey85stang2 wrote:try cleaning the jacks? are they those plastic ones that marshall likes to use?
No![]()
lmao thanks! glad I confirmed
- boris the blade
Rewired the cab. Works as it should now.
I appreciate it my dudes.
