Its not exactly using the best components in some respect as its really just for dicking about with some ideas. Amps that come of it will have more money thrown at them. I'm using an antek toidal PT and a multiprimary 100W OT which has okay bandwidth but isn't too pretty and may well struggle at higher power output. I started with a blank chassis and had to do all my own drilling/punching which is a bit tricky when you don't always know what is going to go in there as I have at least 3 different preamp designs I want to try out.
A few pictures of work to date.
Test fit of the transformers and sockets
Heater wiring
Main filter board
Cathodyne PI board and bias supply. I switched to using PTFE to build on as its much nicer to work with. The turrets are reusable and are mounted with M2.5 nuts rather than being flared to the board to cut down in waste.
The first design I want to try is going to be based loosely on the low gain input of the 8 knob AOR-100 as I love that amp. There is a magic to it which comes from the local NFB recovery stage found after the tone stack which makes it growl in an unholy fashion
Expect this thread to be updated infrequently
