I installed a Dimarzio Super Distortion in the bridge position of a MIM Standard Stratocaster. I used 5-way super switch so that I could split the Dimarzio in position 4. Everything is working and sounds great except for one thing: I am not getting hum-canceling in position 4, with the RWRP Fender single coil in the middle. It should be noted, I am getting hum-canceling in position 2 (neck & middle). I tried reversing the green (start of south) and red (start of north) wires from the Dimarzio, on the switch, but still no hum-canceling in position 4.
The way I have it wired now:
green/bare = grounded to pot
black/white = coil split
red = hot
For reference, per Dimarzio technical support:
Red is start of north and black is the finish. Green is the start of south and white is the finish.
Any thoughts or ideas?
Thanks in advance.
Wiring Question
Re: Wiring Question
Just wondering... don't you need a second switch to make a four conductor humbucker, single coil?
This PDF download explains....
https://c3.zzounds.com/media/4Conductor ... 824dca.pdf
Re: Wiring Question
ajaxlepinski wrote:Just wondering... don't you need a second switch to make a four conductor humbucker, single coil?
No. I'm using a Fender Super Switch.
https://www.premierguitar.com/gear/expl ... per-switch
Re: Wiring Question
How do you have the three pickups wired to the super switch?
Re: Wiring Question
ajaxlepinski wrote:How do you have the three pickups wired to the super switch?
I can't remember exactly which lugs I have each pickup wired to without taking the guitar apart. I do, however, know that I am getting a split humbucker and the middle pickup, in position 4.
Re: Wiring Question - Problem SOLVED
Reversed the wiring to be:
white/bare = ground
red/green = coil split
black = hot
This resolved the no hum-canceling issue in position 4. However, it caused the pickups to be out of phase.
Solution:
black/bare = ground
white = hot
This gave me a split bridge humbucker and hum-canceling, with a middle Fender RWRP single coil, in position 4. No out of phase.
white/bare = ground
black = hot
Solution:
black/bare = ground
white = hot
Re: Wiring Question
Glad you worked it out!
