Wanted: 18v power supply
Need a replacement for an MXR 10 band eq. Anyone have one before I buy new?
Crandall full stack nightstand
- Tortuga
Re: Wanted: 18v power supply
I've had good luck with a laptop power supply (many are 19.2V), to which I soldered the correct connector.
Before I hooked mine up, I checked with MXR (Dunlop), and they gave me the OK - here's a copy of my correspondence with them:
Sent: Thursday, May 30, 2013 4:09 PM
To: TechRoom
Subject: MXR 108 power supply
Hi - I'm setting up an MXR 108 on a pedalboard - I've got a 19.2 volt computer (laptop) power supply that will fit much better than the supplied unit, and am wondering if the 108 will operate okay at that voltage.
Thank you
TechRoom <techsupport@jimdunlop.com>
May 31, 2013, 8:40 AM
to me
Hey Steve
The M108 should be able to handle the 19.2v. You just need to make sure that the power supply has the correct positive barrel negative center polarity.
Thanks
Ryan
Ryan Smith
Electronics Technician
Dunlop Manufacturing, Inc.
1-707-745-2722
rsmith@jimdunlop.com
http://www.jimdunlop.com
live to play live®
__________________________________________________________________________________
CONFIDENTIALITY NOTICE
This e-mail and the documents accompanying it contain confidential information which may be privileged. If you are not the intended recipient you must not disclose its contents, make copies, or take action in reliance upon it. If you have received this email in error, please immediately notify the sender, preferably by return e-mail, and destroy the message as well as any documents attached. Any attachment with this message should be checked for viruses before it is opened. We cannot be held responsible for any failure by the recipient to check for viruses before opening any attachment. Copyright in this e-mail and attachments are created by and belong to us. The contents of this communication represent the sender's personal views and opinions, which do not necessarily reflect those of the Company. Thank you ____________________________________________________________________________________
- Bassman overhaul - G-MAN
- Tortuga
Wrong in what way? If it's the connector, it's fairly straightforward to solder another one on (minding the polarity), as long as you've got any experience with a soldering iron.
