This could be a massively dumb question.
I have a Mk1 Line 6 Spider, 50w 1x12 version and I'd like to add an external speaker port onto it.
Now obviously the easy way would be to just have a switched socket that turns of the internal speaker but I'd like to find a way to do it with keeping it running as well.
I have a 2x12 that I want to use at the same time and/or end up with a 4x12 eventually plugged into it.
I'm sure I'll hear a bit of Line 6 Spiders suck here, but the first versions if these amps are way better than the newer ones. I love the sound of it and I'd like to use it with more.
So the question is, is there a simple way to accomplish this without messing up the rating that I'm attaching to the amp with 3 speakers?
I am now wishing I had the 2x12 version but you work with what you have.
Failing this I'm not far off selling all my amps and just buying a head and 4x12 cab.
Marc
!m!
