JCA2112RC problem
- Dusty Boots
- New Member
JCA2112RC problem
Hey fellas, HC defector here. I'll just cut to the chase. So I've been very busy with work this year and fired up my amp for the first time in months and months today and ran into an issue. I struck one chord and not a half second after I hit it, the sound cut out and I couldn't hear anything. I fiddled with the amp volume and with the volume at about 7 I could faintly hear sound again, and at max volume it was still below talking volume but still audible. I turned the volume down again to half, played a chord and it cut in again for only a half second scaring the piss outa me. After fiddling with different cables, other guitars, it never cut in again, and I could only faintly hear it at high volumes. Now my limited knowledge has caused me to suspect a couple things. I've had the amp for over two years now, I have never changed the stock tubes, but then again it hasn't seen heavy use. So could it be tubes? The fact that it cut out and in and out has me thinking it could be a connection issue somewhere, or potentiometer issue. Before I rip the bad boy apart or take it to a tech, does anyone have any insight into what this problem may be? Thanks fellas, and I apologize for the long winded post.
- Mesa/Kramer
Re: JCA2112RC problem
Check da Tubes
Soldano SLO 100
Marshall DSL 50
Mesa Boogie MK III
Peavey 5150 II
Bugera 1960
Jet City JCA 50
Jet City JCA 20
ADA MP-1
Marshall DSL 50
Mesa Boogie MK III
Peavey 5150 II
Bugera 1960
Jet City JCA 50
Jet City JCA 20
ADA MP-1
- Dusty Boots
- New Member
Mesa/Kramer wrote:Check da Tubes
Do you think it's a pre or power issue? Or is a complete retube in order? Is Doug's tubes still a good place to go? Sorry fellas I've been out of the loop for awhile.
- Dusty Boots
- New Member
Sorry for the bump fellas, just wondering if anyone else has any insight.
- KCTigerChief
When it does it, are your tubes glowing bright red? If so, definitely replace the power tubes.
To me, it sounds like a power tube issue...It could be a pot or a ground, but not likely. Tubes are the easiest to verify. Do you have another amp you could pop the tubes out of and test?
Good luck man!
Good luck man!
Bogner Ecstasy :: Bogner 4x12
