Does anyone here own a kemper?
guidedbyechoes
Post by guidedbyechoes »
I have some stupid ass questions for you.
paolojm
Re: Does anyone here own a kemper?
Post by paolojm »
I've got a Kemper, ask me anything son.
Want
FastRedPonyCar
Post by FastRedPonyCar »
What you want to know?
Tokai LS150, Charvel San Dimas, Strandberg Boden Standard, Martin GPC-Aura GT
Splawn "MUFASA" Nitro, Friedman Runt 50, Brit-Tone SLO+, MadRyan 50w Silver Jubilee
izzy
Post by izzy »
Don't lie:
Most of you wants:
You anted up a narcissistic boil and a conniving witch. Thanks America. Signed, the world.
Tom
Post by Tom »
izzy wrote:Don't lie:
Most of you wants:
Truth
Aka Gsxrbusa
Repner
Post by Repner »
Yep. I'm glad I held back until now. I need that rack version.
redeyes
Post by redeyes »
I do, owned it for a year.
this board is pretty much the same looking as rig-talk which is super win, hopefully the douche brigade is not here
guidedbyechoes
Ok so my questions are If you were to take a model like the twin reverb or a plexi and use a real pedal say a fuzz would it behave like an actual amp with a pedal in front of it?
Have they issued a patch that extends the low end capabilities for profiling bass amps?
If I turn up the volume on a non master volume amp will it act similar to the counterpart?
Does it have the ability to adjust sag and other parameters similar to the axe fx?
If I were to engage a pedal while profiling would it capture the exact tone I had? I'm pretty sure overdrives and the like work but I meant stuff like modulations and delays.
Can you use the unit for vocal processing?
Have you ever encountered digital clipping?
redeyes
Post by redeyes »
guidedbyechoes wrote:Ok so my questions are If you were to take a model like the twin reverb or a plexi and use a real pedal say a fuzz would it behave like an actual amp with a pedal in front of it?
Yes Fuzz into a fender profile will act like the real amp and give you the correct tone. Also there is fuzz built into the effects which you can try.
The Kemper can profile bass as well as guitar, there are bass profiles, use them and enjoy.
It can adjust sag and other parameters for the amp block. You can profile an amp at any volume level and saturation. The master volume on the Kemper does NOT act like the master on a real amp, it is the overall output level.
You can profile an amp with an OD pedal inline, it will capture the tone of the entire signal chain.
Modulations and delays cannot be profiled.. I think time based effects are a no go while others are.
Vocal processing? no idea, im sure it would give you distorted tones jsut fine. Probably effects would be fine as well although they are tuned for guitar range.
You can get digital clipping if you crank the volumes on the Kemper and your DAW cannot handle it. There are LEDS which allow you to tell when you reach these levels. It is easy to prevent clipping.
How expensive are the patches you can download?
How are you finding amps to profile besides yours & your friends?
guidedbyechoes
I meant is there and xlr port for the vocals part. And I knew there were already bass profiles. I meant have they improved them as before the profiler was rumored to not pick up the full range.
I figured that trying to capture delay or modulation would just make it sound goofy. I have pedals to do that. I am just ultimately deciding what I need to keep or get rid of. Since I want it just for recording and I really have no need for all the tube gear I have since I don't play out.
guidedbyechoes
sleewell wrote:How expensive are the patches you can download?
They have a community of free ones and the paid ones very by person selling them. In most cases like 20 bucks per amp/cab combo.
guidedbyechoes
KCTigerChief
Post by KCTigerChief »
Are they actually releasing a rack version???
Uh oh...
Bogner Ecstasy :: Bogner 4x12
guidedbyechoes
KCTigerChief wrote:Are they actually releasing a rack version???
Uh oh...
No it's just to get you interested enough to decide you can make the space toaster work.
:ymdevil:
jk it's like 50 bucks more
FastRedPonyCar
boosting the kemper with an overdrive sounds good depending on what type patch you're using but doesn't sound like a preamp tube circuit being overdriven. I can take my nitro profile I made WITH my austin boost hitting it and play a bit and then switch over to my non boosted profile and then turn on the austin plugged in front of the kemper and they don't sound the same.
mind you it's not a WORSE tone when boosting the profile, it's just different.
guidedbyechoes
FastRedPonyCar wrote:boosting the kemper with an overdrive sounds good depending on what type patch you're using but doesn't sound like a preamp tube circuit being overdriven. I can take my nitro profile I made WITH my austin boost hitting it and play a bit and then switch over to my non boosted profile and then turn on the austin plugged in front of the kemper and they don't sound the same.
That makes sense. Because the mic doesnt capture every single frequency and amount the amp puts out. Sort of like how an amp sounds in a room versus a recorded tone. The mic causes some frequency roll off before the kemper. SO it would stand to reason that putting the boost after the model would work differently, but also can expand your tonal palette. Which I think is a good thing.
gt_jumper
Post by gt_jumper »
Just buy it, thank me later.
My recordings - https//:soundcloud.com/brootz
FastRedPonyCar
gt_jumper wrote:Just buy it, thank me later.
pretty much this.
Sounds like
http://www.youtube.com/watch?v=yAPksYYM3qA
Killa J
Post by Killa J »
Anyone know if they are making a non-rack version with the built-in amp? I have no other rack gear, so I wouldn't want one just for the Kemper.
madrigal77
Post by madrigal77 »
Killa J wrote:Anyone know if they are making a non-rack version with the built-in amp? I have no other rack gear, so I wouldn't want one just for the Kemper.
They are. Retail is $2730.
ESP MX-2 White
ESP Eclipse II Vintage Black
LTD EC-1000T CTM Violet Shadow
Ibanez Acoustic: V300CW
Fractal FM3 MKII Turbo
Laney LFR-212
FastRedPonyCar
From what I've heard, the built in amp is only going to be very very low powered. Not like a dual 100 watt thing jammed in there. Think like a little 5 or 10 watt practice amp type deal. They may have changed things since then but that's the last I heard on it.
madrigal77
FastRedPonyCar wrote:From what I've heard, the built in amp is only going to be very very low powered. Not like a dual 100 watt thing jammed in there. Think like a little 5 or 10 watt practice amp type deal. They may have changed things since then but that's the last I heard on it.
It's the same 600w as the rack.
http://www.rig-talk.com/forum/viewtopic.php?f=3&t=130246&p
ESP MX-2 White
Laney LFR-212
FastRedPonyCar
Oh LAWD
It is required to send the Profiler to the manufacturer to install the amp safely.
