Works as it should. Power supply included.
http://www.voodoolab.com/controlswitcher.htm
Add MIDI automation easily to any channel switching amp!
Switch channels on multiple amps and easily automate any non-MIDI functions with Control Switcher. Using a midicontroller (ie: FCB1010), Voodoo Lab’s new Control Switcher gives you instant MIDI programmability for controlling all footswitchable amp functions including channel switching, reverb, boost, EQ, loop and more.
Features 4 completely isolated relays with front panel instant access buttons, separate 1/4” mono outputs and a multi-DIN connector. Runs off a standard 9V power supply and is compact enough to mount behind an amp, inside a rack, or on a pedalboard. Dimensions are 6.2 wide x 3.1 deep x 1.2 height in inches.
Control Switcher Features:
4 isolated relay controls
Front panel instant access buttons
Separate 1/4" mono jacks
Multi-DIN connector for modern amps
Controls any footswitch function
Phantom powered by GCX or Pedal Switcher via MIDI cable
Works with Program and Control changes
Voodoolab Control Switcher $125 USD sh/pp'd Cont USA/CAN
ShaneV wrote:So Bugera is Bugeraing cheap Chinese amps now? It's just a matter of time before they accidentally Bugera a Bugera.
