Tips for 'sweetening' up a mix
- Elessar [Sly]
So I've got sounds that work with eachother etc. But how do I polish the hole track? any tips?
- Loins of Fire
Re: Tips for 'sweetening' up a mix
You need a plugin like Ozone 5 which has modules for EQ, Harmonic exciter, compression and stereo widening. The process you are talking about is called mastering which is basically shaping your master bus once the mix is done.
As for in th realm of mixing, saturation plugins on your bass tracks, vocal and drum buses, and master bus. Good freebies are TesslaPro or FerricTDS. A very light bus compressor on the master bus. Slate VCC on every track if you want to go the extra mile. More character compressors on the tracks with very light settings, I like what the Pensadia SOR8 does for bass guitar (Distressor modeler).
Get this: http://www.bbesound.com/products/sonic- ... sweet.aspx
It will be the best US$150 that you ever spent!
The Sonic Maximizer and Harmonic Maximizer will take all the muddyness out, brighten up your mix and beef up the low end.
- RustyMetal
Elessar [Sly] wrote:So I've got sounds that work with each other etc. But how do I polish the whole track? Any tips?
I agree with nakedzen. A tape saturation plugin. The compressor and limiter on the master bus is good for 'mastering' type functions, but a saturation plugin may help add a little sparkle to the track. Or not. It doesn't hurt to try.
"That's not surround sound, that's in your face sound"
blame it on my dain bramage
Epi SG / Dean Vendetta XMT, & 1000
Boss GT-3 / Pedal Case Full of Pure ROCK
Marshall 3210 Mosfet & Kustom 4x12 / Peavey Vypyr Combo
Great deals!: JonVengeance, ColeJustesen, DoubleBarrel, SpeedBag-x2
- overdrivenel34s
Antress has free vst plugin called "analoger" which has various presets including tape and tube coloration. There are also a wide rand over other plugins in same "modern" series including limiters, compressors, eq, etc.
