Looking for standard LP layout - 2 hum - 2 vol - 2 tone - 3 way
Is is possible to have (4) push-pull pots and have it wired for series-parallel and a coil split on each pickup?
I guess in a perfect layout - the series-parallel wouldn't do anything (but would work in either position) if you had coil split chosen on the other pot.
I would put the series-parallel on the volume pots and the coil splits on the tone pots.
I've looked around the web - but can't find this layout.
If I can't find this diagram - may just go with the bridge wired standard - and a series-parallel on the the neck.
edit - I may go this route and get everything I wanted with standard pots.
Anyone have any experience with these?
Seymour Duncan Triple Shot Pickup Rings
http://www.musiciansfriend.com/accessories/seymour-duncan-ts-2s-triple-shot-carved-top-pickup-mounting-ring-set?pfm=sp
Is this wiring possible? - or anyone use these?
- clipless
Last edited by clipless bumper on Mon Jun 16, 2014 1:35 pm, edited 2 times in total.
Re: Is this wiring possible?
Check out the wiring diagrams at guitarelectronics.com ...they might have what you're looking for.
- clipless
I saw those - didn't see one like this.
the 4 push-pull usually involve out-of-phase as at least one of the choices.
Re: Is this wiring possible? - or anyone use these?
it is possible to do. i have drawn a schematic specifically for you. let me know if you have questions. it was a quick sketch.
