FT Baron B60
shane159
FT Baron B60
Post by shane159 »
I am probably going to regret this, b/c this is easily one of the best amps that I have owned, but I am an amp whore :cry: .I am looking to trade my Baron B60, handwired with some of the best components available. These run new at $1700, and there is a 6 month waiting list as of now to even get one of these fantastic amps. The cosmetics on this one are a one off design based on the Bogner Ecstasy. Is it based on an Ecstasy? I honestly don't know, but it has a better Clean Channel than the Shiva I had and it can get crunchy as well. Along with the cleans it also has two stages of gain on the OD Channel. The footswitch controls all of the functions except for the bright switches and the Power amp settings. The controls on the footswitch operate the channels, vintage/modern modes, Gain A or B, FX Loop, and a seperate boost for the OD channel. This amp is the most versatile amp that I have ever owned. It is 60 watts and has a brand new set of Winged=C= EL34's. There is also Presence, and Thump dials for the Poweramp section, as well as a tight/normal switch. The only thing wrong with this amp is that the bright switch on gain A is a tad touchy, but works perfect. The customer service for these amps are also amazing. You will get an answer to any questions within a day. I am only looking to trade towards Tube amps, or Guitars. The only reason that I am wanting to trade it is b/c I prefer single channel amps for the most part, and this thing just has way to many options for me. I end up tweaking instead of playing. Thanks and here is a link to a demo of the exact amp. I am thinking a trade value of around $1,300. Open to all offers, but looking mainly for tube amp heads. Marshall, Mesa, Orange, etc.
Dirty:
[video]http://youtu.be/zsedMA-GdcE[/video]
Clean:
[video]http://youtu.be/Hk6I5J7HRP4[/video]
Specs from Barons website:Features
2 channel hand-wired, all tube head Made in USA!
High gain "crunch" channel and a "clean" channel
High gain channel with Vintage/Modern Gain Modes.
Medium ad High Gain Modes have a switchable "Dry" or "Wet" Voicing's
Switchable Bright switch emphasizes Hi-Mids or Hi treble frequencies..
Totally independent channels with separate tone stack and volume controls
Global master volume with thrust and presence controls
Power amp response switch for normal or tight power amp response
Serial effects loop (+4/-10dB) can be switched in or out of the signal path
Impedance selection of 4, 8, and 16 ohms.
Foot switchable channel, boost, effects and gain A/B selection
5 12AX7A pre amp tubes (2 EL34 60 watt),( 4EL34 120 watt) power tubes (Can also use 6L6GC type tubes.)
Footswitch included.
The B60/120 series are versatile amps that covers a large palate of British amp type tones. They can use various types of power tubes and have versatile voicing options for every player's needs.
Each channel is completely separate with its own tube stages and tone stacks for no compromise in tone or versatility.
The clean channel gives you pristine warm squeaky clean tones to warm bluesy with a little breakup. Great for all kinds of music.
The crunch channel takes you from vintage crunch , all the way to modern hot rodded british high gain tones. Dual gain modes (Medium and High) allow the player to set the amp up just right for the type of tones you are looking for. The Vintage and Modern voicing add to the flexibility of the crunch channel. The distortion is tight articulate and full of warm harmonics. You can go from clean mild breakup to chewy ballsy high gain tones The gain structure of this channel is voiced for vintage rock, all the way to modern hot rodded searing lead tones.. The full "British" spectrum of tones are available here!
Power amp voicing with presence thrust and responses control adds more flexibility. The thrust control adjusts the low end response of the amp as well as the presence for the high end response of the amp. The response switch allows how tight the power amp reacts, for even more options in tone.
Effects Loop that is fully transparent and pedal/rack friendly and can be fully bypassed if desired.
Good deals: Guitar Billy, Crunchtime, Draco Aron, Holy War, Crank, Yo Squig, Moops, Elemenope, Edge of Darkness, Abstract, Chris JD, Ricky Rockhardo, Norton 666, Freehandarson, Dolf, Van_Muddlestein, Yarbicus, Schweezly, Nateispro, Conky, MikeO, Whiskey Face, Broslinger, Mamberg, Ajaxlepenski, Ovid 9, SAH5150, Axe, Greatmutah, Rubyguitargod, Hardvalve, JerEvil, Jive Turkey
