valtyr wrote:I have my Helix connected to my computer for recording but that’s pretty much the only time I use it. I stick with mostly tube amps the rest of the time.
Digital sounds thinner, even with synthesizers. Just 3 voltage controlled oscillators in a Moog will destroy any virtual analog or software synth in a mix every time.
Right???? That's exactly what I was getting at. Moogs are the perfect example. There's just no comparison how heavy they sound vs digital synths. Hammond organs too. Jon Lord carried his massive B3/Leslie rig to gigs until the end of his life because he said there was no way he could get his synthesizers to compete with the guitar like the Hammond did.
It's not modeling per se, it's digital as whole. It applies to pretty much every analog vs digital comparison.
Obviously, it's nearly impossible to have an 100% analog signal chain these days. Most modern PAs are digital, most records are done with DAWs etc. And the vast majority of people listen to music on digital devices.
But still, even if it gets converted to digital at some point, the longer you can keep your chain analog the better.
For example, using the amp through a cab with a mic is the best possible solution, but if you can't do that, using the amp with a load and a good sounding analog DI is still a very good option.
If you can't do that either, running the amp through IRs is still better than going full digital.
That notion that "if you're going DI you might as well just go full digital" ... no no I don't agree with that. The real amp with the load/IR will still sound better than the modeling, especially in a live mix.
If you need to replace the cab/mic with DI, do that, but keep the rest of your chain intact, no need to throw the baby out with the bathwater IMHO.
