Schaller Pickup Set
These came from my 2004 Heritage H-150. These are just the stock Schallers that came with the guitar. Solid pickups, and I liked them quite a bit, but I put Motor City Pickups into that guitar. Short legs, 4 conductor wiring. Neck is 7.23 K and Bridge is 8.01 K. SOLD
Gibson Burstbucker Set
These came out of my 2004 R7. These are Burstbucker 1 and 2 pickups. Not measured but the 2 is usually slightly hotter than the 1 (and to be honest they balance well with the 1 in the neck and 2 in the bridge). Interestingly enough, unlike off the shelf Burstbuckers you can buy as an aftermarket upgrade, these are wax potted. Nickel plated finish (you can see the bridge is starting to patina a bit). Long legs, 2 conductor wiring. SOLD
Duncan 59s in Gold
I've had these two for a bit. Both are gold plated. I have not measured them yet. One of them is a bridge model and the other a neck model. The bridge model came out of my H-157 (I swapped in a SH-5 custom there) and it sounds fantastic. I bought the neck model used and never installed it. The neck one may originally have had a different color cover as there are cut lines in the solder on the back. Also the pole piece screws are nickel and don't seem to have any gold on them whatsoever (the pole piece screws on the bridge have also faded, but they have gold in the crevices for the flathead screwdriver). At any rate, these are being sold separate. You can get both if you want also. The neck is slightly cheaper due to the reasons I've listed. Both are 2 conductor wiring with long legs.
Bridge - SOLD
Neck - SOLD
Bridge pics:
Neck pics:
