so i buy all my amps used, when i bought this amp....hooked the scope up to make sure everything was testing fine....and i got one hell of a parasitic oscillation coming through.
so i took the chassis out of the cab and started doing more inspections around the PCB...and i noticed something odd.
i dont see the 47pf cap that usually goes across the PI stages plate resistors......either im blind....or its not on the board at all. most people think of this as a fizz cap and it does remove alittle fizz....but its actually in place to prevent oscillations from happening.
so after i placed a 47pf cap across the plate resistors of V4 ( the pi stage )....the parasitic oscillation went away....and i got a smooth sinewave from that point on.
if you can follow the picture above, and place a 47pf cap across the plates of V4....just like the picture shows.
the reason im talking about this, i bought my amp a good while ago....and i figured maybe someone cut it out doing some type of science experiment....until a friend of mine brought 2 of the dsl40c amps to me to do some touch up work....and he mentioned 1 amp was burning through V4 left and right....and the 2nd amp sounded out of place.
and ill be damned....both of these dsl40c's....which were bought brand new....had the exact same problem.
if you dont own a scope and cant test for oscillations, its still safe for you to place a 47pf cap across the plates of V4....just to be sure...and safe
EDIT: i forgot to mention, make sure the capacitor is 47pf with a min rated voltage of 500v
