Anybody else try out Kazzrog's KClip plugin?
KClip, from the guys that make Recabinet.
If you have the VIP pass on Recabinet you get it for free, otherwise it's $19.99. Really great clipper/limiter. The thing I've dug about it is the ability to turn off the hard limiter (the Guard switch) so you get a real read of what you've done with the gain and output level settings, set your clipping to either hard or soft and check your levels after, then flip on the Guard and set your overall ceiling. Seems to work perfectly so long as you don't attempt to make the Guard/Ceiling do the work for you. Seems quite a bit more clear from other clippers I've used (TRacks clipper and Slate Digital FG-X). Works great on the master bus but I've dug it on the bus for vocals and clean guitars to even levels out a bit before it hits the main mix. Note: This is not a colorful clipper. You want color, better off looking at something like Slate's FG-X. You want crystal clear leveling, this does the job.
Pretty cool and incredibly cheap option for clipping/limiting if that's something you need.
Re: Anybody else try out Kazzrog's KClip plugin?
fretless wrote:have you tried Gclip ?
http://www.kvraudio.com/product/gclip-by-gvst
Nope. I live in AU/Mac land though, so that's not really an option for me.
