NAFD! (HEAVILY modified amp content)
benjamin801
Post by benjamin801 »
So, I've been using a Mark III (again) as my main amp for a little over two years, and in a four space SKB rack for over a year of that time. While I was using it on the Redstar Audio 2x12, which is super deep (like 17"), all was well, but when I bought a Recto Trad Slant 4x12 (again) a month or two ago, which is only 11" deep at the top, I quickly found that the feet on the SKB were spaced too far apart to get good footing on the top of the cab. This made the rack tilt slightly backwards, and worse yet, left the rack case rubbing against the tolex.
Unacceptable.
So I bought four oversized rubber amp feet ($9 shipped). Like, cabinet size. And, drill in hand, installed them forthwith, at the correct spacing to sit perfectly atop my Rectocab. Look upon my works and despair, motherfuckers:
Note the laughably puny stock feet, sitting there and looking small, worn, and inadequate as me in the locker room shower at the gym. Anyway, happy NAFD (new amp feet day) to me.
:idk:
Macelind
Re: NAFD! (HEAVILY modified amp content)
Post by Macelind »
Holy fucking cow! You did that all by yourself? Excellent work.
Seriously, way to go to solve your problem. Now, try some Enzyte for the other problem.
benjamin801
Macelind wrote:Holy fucking cow! You did that all by yourself? Excellent work.
Inorite? I've seen some dudes open their own shops on similar credentials.
Macelind wrote:Seriously, way to go to solve your problem. Now, try some Enzyte for the other problem.
Best thread of the day
