Some quick background... through my 2 different studio experiences I had access to all kinds of mid to top line stuff (consoles, preamps, mics, decent rooms, etc). About 5 years back I went through a massive sell off of basically all my personal studio stuff. Some of the amps/guitars that I have are a direct result of this 2 year long purge. I was done with recording
Basically all I was left with was 2 SM57s, a Sennheiser MD421 II, and a Radial Reamp box.
2 years ago I got the bug again. This time though I was determined to keep it as simple as possible so here's the gear:
MacBook Pro
Apogee Duet
SM57/MD421
Radial Reamp Box (don't use this too often - prefer to get the recordings right off the cab)
Rivera Rock Crusher (not shown)
Monitors are important right?
I do everything under cans right now as I sold my monitors recently (looking for new ones but no rush). These are Sennheiser HD650s and although they are fantastic I struggle with low end mixing a little.
As far as software goes:
DAW is Logic Pro X
Amp Modelling - Amplitube 3 (including Ampeg SVX), BIAS Desktop, Various Free Amp Sims
IK Multimedia T-Racks (I use their channel strips, bus comp, and brick wall limiter on my stuff)
Drums are Superior Drummer 2 and ezDrummer 2
Two Notes Wall of Sound Cab sims
Basically my process is pretty straightforward and I mostly stay in the box for plugs. Since I got rid of my SVT I do all bass direct using Ampeg SVX + the in the box logic guitar amps/pedals for grit. Guitars are usually scratched out using amp sim plugs then re-recorded "live" either using the Rock Crusher silently and the Two Notes plug or miked up and blasting. I used to reamp more but I have found doing it straight up makes the guitars more lively.
Drums are fun... I had 2 different setups with Superior Drummer 2 that used to be my go to sounds but since ezDrummer 2 came out I just use it... they sound better than my old SD setups. Besides the OOB ezD2 drums I use the Metal Machine, Metal!, and Blues expansions.
So thats it... pretty simple and compact setup.
I do want an interface for handling drums, new monitors, more mics (ribbon, drum), and preamps but no rush...
