Diamond Phantom head
primerib
Post by primerib »
The mighty Phantom by Diamond Amplification. 2 channels. Gain channel has 2 volumes and 2 gains that are foot switchable. Wonderful clean and gain tones. All hand made in the USofA.
These amps cost well over $2000 new. Save big money on a great amp.
http://www.diamondamplification.com/phantom.html
Specs:
• 100 watts (4 x Svetlana "Winged C" EL34 - 6 x 12AX7)
• 2 fully independent channels (Channel 1 - Clean/Channel 2 - Crunch)
• Both Channels feature Volume, Gain, Bass, Middle, Treble, Presence
• Dual Volume/Gain Channel 2 (switchable, allows for two gain settings with 2 volumes for level adjustment to match volumes)
• Rear panel low frequency 3-position adjustment switch (allows for changing the amount and character of the bottom end - effects both channels)
• 100v, 120v, 220v and 230/240v output selection.
• Ohm selector switch for 4, 8 or 16ohm output.
• Green LED's light the box for a distinctive look on stage, along with a unique silver vein front grille and stainless steel logo.
• All components specifically spec'd and tested by Diamond before inclusion in the product.
• Independent LED's indicate which volume/gain is active and whether the boost is engaged.
• Properly designed, tube-driven effects loop (shorting jack so the loop will automatically engage when cables are plugged in and disengage when cables are removed).
• Front panel Effects Return control that acts as an overall master when loop is engaged for quick overall volume adjustment.
$899 plus shipping and PP fees. Word up!
I've done tons of deals on HC as hcprimerib.
Owenmatt
New Member
Re: Diamond Phantom head
Post by Owenmatt »
Have you sold this? I am interested.
