Man, those Splawn cabs are pretty. The tolex on the corners is so perfect, I thought for a minute it was a spray coat.
benjamin801 wrote:The tolex on the corners is so perfect, I thought for a minute it was a spray coat.
Good eye - it is spray coated
I had the cabinets coated with duratex. Splawn has a special method of application that makes it look like tolex
Oh, OK, good. I'm not going crazy.
Y0UNGBL00D wrote:dude your cabs and guitars are obviously inferior. you should probably just get out of here.
im kidding. dat ibby finish you did that?
If weight equals inferiority then you would be right - those cabinets weigh just as much as I do
Yeah the Ibby finish I am responsible for. Took the guitar completely apart and spent quite a few hours bringing the finish back up to a mirror shine. It was part of a collection fromf a store owner in SC. I did an even trade with another guitar, and gave it some TLC. It now has a JB in the bridge, PAF in the neck. One of the best playing guitars in the lot
Amplifiers: 1974 1959 JMP Superlead MkII / 6550s 2015 Metropoulos MetroPlex #001 / EL34s 1998 Bogner Ecstasy 101B / MM Iron / EL34s 1994 Laney GH100S 100W / EL34s 2005 6505+ Head / MM Iron / 6CA7s 6505MH 20W
Amps aren't really all that special. 5150 II that is far from stock, and a low serial number '94 mesa Tremoverb. I did gut the 5150 II and turned it into a 2 channel amplifier. Currently working on a lead volume/gain boost design to replace the crunch channel. I much preferred the lead channel gain turned down for crunch. Sounds good.
The tremoverb is under the knife. Designing a quad bias system and beefing up the power supply for quad KT88's. Improving a few designs, and currently board designing in what little free time I have.
Welcome man! I'm pretty sure I remember you from HCAF.....didn't you have an avatar of a kid with a "beard beanie" for a while? Or did I just imagine that?
Awesome gear!!
