Vocal mic? I need help gaiz
Holy-diver
Post by Holy-diver »
so I have been recording my clean style vocals with an sm57 and it just is not cutting it... the vocals sound flat and dead no matter what I do the mic also has an almost nasally quality... it just doesn suit me for vocals at all. my clean vocals are kinda alice in chains esque (I'm not the greatest singer by any means either) so what would yall recommend? preferrably something I might be able to afford as well :cop: I don't have a budget per se but I don't want to spend hundreds on it. thanks dudes
Cobrahead1030
Re: Vocal mic? I need help gaiz
Post by Cobrahead1030 »
This is a solid one, it works ok on guitar cabs too...
http://www.sweetwater.com/store/detail/AT2020/
This one also...
http://www.sweetwater.com/store/detail/B1Mic/
A step up would be this...
http://www.sweetwater.com/store/detail/NT1AAnniv/
Holy-diver
how is the sm7?
Cobrahead1030
Haven't used one myself.
Holy-diver
the rode seems like it might be a good option... any more input? I appreciate the help!
colejustesen
Post by colejustesen »
You might look into the Superlux CMH8A... A review done by Sound on Sound compared it to the Rode NT1 and said it had similar sensitivity and overall tonal characteristics...
http://www.soundonsound.com/sos/jan02/articles/superluxmics.asp
These are considerably cheaper than the Rode and seem to sound good (as far as the clips I have heard of people using it). As far as the brand goes, I got turned on to them by the people on Gear Slutz for their studio headphones (I own a pair and love them!), and decided to venture into their microphones too. I ordered a dynamic mic just the other day to try, and I anticipate getting one of their small diaphragm condensers to use for my acoustic guitar.
They aren't overly expensive either!
If you want to stay with a trusted name, I imagine that you will have good luck with the Rode NT1A! Also the KEL Audio HM-2D might work for you too :thu:
Good luck!
Amps
Hughes & Kettner Duotone
Laney GH100L
Peters Halo/Hydra
Rivera Chubster 40, M100
Rocktron Vendetta 100
VHT Pittbull 100/CL
Budda 2x12 (Jensen C12K2)
Rivera K412T (Eminence CV-75)
Splawn 2x12 (Fane M65)
esizer
Post by esizer »
Tried and true 58! You can find them on CL all day long.
Of things we've done
Caligula would grin
Cirrus
Post by Cirrus »
57 and 58 are the same mic capsule with a different shaped end - 57 has flat grille for sticking close to sources, 58 has ball grille end because that feels better to put your mouth right up against but still gives a cm or so distance from the diaphragm. The shape of the plastic and metal around the capsule change the response slightly but it's nothing major.
So if a 57 doesn't cut it, a 58 probably won't do much for you either. That said, i do find they respond well to high shelf boosts - say 8K and up - assuming your voice isn't too sibilant.
The SM7b also has the same capsule, but it's mounted further away from the body of the mic, the foam keeps your mouth even further from the diaphragm and it doesn't have a transformer which means lower output but better sound, basically. It's a great vocal mic if you have a bright, loud voice so for some rock singers it's perfect.
The SM series use Alnico magnets which are a bit soft and spongey. The Beta series use Ceramics and it's the same effect as in pickups and speakers - the ceramic magnets are a bit clearer sounding.
It sounds like you're wanting a condenser mic sound. That's a whole world of possibilities depending on budget!
Holy-diver
I don't feel comfortable spending more than a couple hundred bucks. this is great input guys I appreciate it :)
esizer
Post by esizer »
Cirrus is the fuckin man :thu: Always very valuable opinions.
Caligula would grin
Holy-diver
any more input? I thinkn I may try the rode
frumiousbandersnatch
Post by frumiousbandersnatch »
The Blue Encore 300 is awesome.
Post by Elessar [Sly] »
colejustesen wrote:You might look into the Superlux CMH8A... A review done by Sound on Sound compared it to the Rode NT1 and said it had similar sensitivity and overall tonal characteristics...
Good luck!
My father bought some superlux headphones and they sound great! He has been considering getting their drum mic set.
Hear is a different approach to "flat and dead"...
Use a BBE Sonic Maximizer or an Aphex Aural Exciter.
You can still get them in analog rack mounted form or, you can get them as plug-ins.
They take all the muddyness out of vocals, guitars, any instrument and they work wonders on final mix downs.
I haven't tried the plug-in version but, I'll never mic anything without passing it through my BBE.
Hope this helps!
'63-Strat
Post by '63-Strat »
Homestly a 57 run through a good mic preamp can sound great on vocals. Chris Cornell and Sting have used 'em. Without hearing a clip it's hard to say but if it's sounding nasal that would more likely be a tecnique thing and if you are singing nasally a ribbon or condenser would likely only emphasize that more.
Any suggestions for a good pre-amp?
Cirrus
Post by Cirrus »
At the lower end of the preamp market (which is all I've got real hands on experience with), there are two which I think are great;
The Groove Tubes "The Brick" which is discontinued now is a great single channel valve mic preamp with decent transformers and a cool sound - nice and thick. Also great as a Bass D.I. and the only real weak point is that it struggles with some really low output mics.
The FMR RNP is a two channel pre that sounds great. Loads of headroom and clarity.
Thanks!!! That FNR RNP has some great reviews. I'm putting that one on my "as soon as I have US$475" purchase list... :love:
nakedzen
Post by nakedzen »
I've been recording with a Beyerdynamic M201TG lately, I prefer it over the SM7b for my voice. It's also a very versatile mic, sounds great on snare, overheads and guitars.
MSguitar1
Post by MSguitar1 »
Blue Baby Bottle. I love mine.
1963 ES 335
1972 ES 345
1961 Les Paul Jr.
1974 SG
2005 Ric 360 Jetglo
2003 Fender Highway 1 Strat
1963 Fender Jaguar
1989 Fender American Tele
2006 Michael Kelly Valor
1938 Martin 00-18
2009 Washburn WD15S Special Edition
2007 Crate Palomino 16
1993 Fender 410 Tweed DeVille
1980 Carvin 100 Head (2X12 VOX cab)
1959 Tweed Deluxe
1972 Fender Deluxe Reverb
VOX AC30TB
VOX AC15
Why are asteroids in the hemisphere and hemorrhoids on your ass? Isn't that backwards?
MSguitar1
Post by MSguitar1 »
I think you can get them now for $299?
1963 ES 335
1972 ES 345
1961 Les Paul Jr.
1974 SG
2005 Ric 360 Jetglo
1963 Fender Jaguar
1938 Martin 00-18
1959 Tweed Deluxe
VOX AC30TB
VOX AC15
