BOTR 2022: Best Large Pedalboard - 8 or More Pedals
Poll ended at Tue Jul 19, 2022 9:18 am
18%
spawnofthesith
1
6%
duncan
6
35%
18%
bubbastain
4
24%
Total votes: 17
greatmutah
Site Moderator
Post by greatmutah »
Metropoulos Metro-Plex
Orange Rockerverb 50 MK III
Fender '76 Vibrolux Reverb
Marshall 1960A w/ Greenbacks
Re: BOTR 2022: Best Large Pedalboard - 8 or More Pedals
My fun board.
Added the Rubberneck during the past year...
spawnofthesith
Post by spawnofthesith »
Front: Dunlop 535q > Mu tron Micro tron IV> Kirk pitch black > keeley compressor plus
Loop: dinner noise killer > mu troj phaser iii >eqd avalanche run > eqd afterneath > keeley Omni verb > boss rc-500
Moof exp pedal going to afterneath, boss foot switch going to rc-500
duncan
Post by duncan »
Out front: Sonic Research Turbo Tuner TT-200 > Klon KTR > Maxon OD808 > Diamond Boost EQ > Amp
Loop: Diamond Memory Lane 2 > Earthquaker Devices Avalanche Run V2 > Walrus Fathom > Walrus SLO > Empress Vintage Modified Super Delay
Powered by a CIOKS CIOKLATE, sitting on top of a Temple Audio Duo 24
I used to play guitar.
GigRig Three 2 One Guitar Switcher
GigRig G3 Atom Pedal Switcher
Chase Bliss Automatone Preamp MK II
Chase Bliss Automatone CXM 1978 Reverb
Macari's Colorsound Tonebender MKIII
Analogman Bad Bob Boost
Klon Centaur
Line6 HX FX
bubbastain
Post by bubbastain »
greatmutah
Site Moderator
Choose!
Ry Manchu
Post by Ry Manchu »
I can't decide. When does voting close?
Also, why 2 Bion Boosts?
A - A
greatmutah
Site Moderator
You got a week. So plenty of time.
bubbastain
Ry Manchu wrote:I can't decide. When does voting close?
The first one is set up for like a typical boost and I have it set pretty conservatively. The second one I set up in one of two ways. First with the tone knob all the way down to give a thick kinda faux fuzz kind of thing. The other way is with the boost way down to cut gain from my main distortion pedal. They also stack really well.
Ry Manchu
Post by Ry Manchu »
Thanks. What other pedals does the Bion stack well with, iyo?
A - A
bubbastain
Honestly everything I tried it with. Tubescreamer, Badass custom OD, SD-1 and my Donner Dumble drive. The Bion has to go first though. Also, the Bion doesn't like a buffered pedal in front of it. It is my favorite boost/tone shaping pedal.
Ry Manchu
Post by Ry Manchu »
Gracias.
A - A
Ry Manchu
Post by Ry Manchu »
A
A - A
bubbastain
Ry Manchu wrote:Bubbastain, what are the two unpainted pedals? Do you like the ricochet?
The one on the right next to the Boss OC-5 is a Caline Englishman. I put it on the board sometimes when I want a different distortion flavor. That spot is basically the revolving pedal spot. The other pedal I made. It's a volume pedal that's activated by a footswitch. The volume knob is on the side. I use my guitar volume to get clean tones all the time, but there are times I might want to quickly go to a very specific amount of clean up while I'm going back and forth dirty to clean. So I just set the knob exactly where I want it and then have instant access to it. Also, it's located after the gate so if I happen to be using the gate( hardly ever) I can still get the rolled back tones without the gate killing off the notes.
The other function of the pedal is that if a expression pedal that is hooked up to my Delaylab. I move the big wheel ( that is from a weed whacker) with the side of my foot. No need for a gigantic volume or expression pedal
The Ricochet is cool. I had the Whammy DT for a little bit but it was way too big and I only used a couple of the functions. The Ricochet is just the right amount of fun.
Ry Manchu
Post by Ry Manchu »
That is awesome. You are cool. :thu: Lemme know if you ever feel like making another one?
A - A
