Can't hear guitar through laptop
This may be a stupid question, and maybe I'm just not getting it. I have my monitors connected to my Scarlett interface, and the interface is connected to my laptop via USB. The laptop is set to use the Scarlett for sound. Then, my Captor is connected to the Scarlett via XLR. I can hear the computer sounds (clicks, Windows dings, etc) through the monitors, but the only way I hear my guitar is if I turn up the monitor dial on the Scarlett. Is that normal?
Amps: Fractal FM9, Headfirst Amplification JT Jr, Ceriatone Plexi 51, Jet City JCA22H, Marshall DSL40c, Boss Katana Artist, Yamaha THR10x
Guitars: Suhr PT Signature, Peavey Wolfgang, EVH Wolfgang, Gibson LP Tribute, Washburn N24, Frankenstrat, Partsocaster, Squier CV Telecaster, Harley Benton DC Jr
Effects: Line 6 HX Effects
Check out my band: https://www.facebook.com/ungluedband
***1776*** wrote:BTW Your a ampwhore and finniky, to hear you liking the amp is a good thing
- LukeBurke1
Re: Can't hear guitar through laptop
Which DAW are you running? It could be a few different issues:
1) You may be running the wrong driver for your interface. Go into your DAW/VST's settings and select the Focusrite ASIO driver for your Scarlett
2) It could be a routing issue. If this is the case, check the Scarlett's manual to see which outputs are designated for your outputs and check the output routing in your DAW to make sure it's set to output to the monitors
3) When you play, do you see the meters flashing in your DAW? If not, try arming the track for recording.
4) I think Focusrite uses a desktop application now that can control the interface's levels and possibly routing. Your issue could lie with that app.
Gibson Les Paul Traditional Pro II
Gibson SG-3
Gibson Les Paul Special
Vox AC30HWH
Janice Cabs 2x12 (Creamback 65s)
Good Deals with: rleechb, _ej_, phillbis, Axe, V/Rad Studios, boris the blade
Gibson SG-3
Vox AC30HWH
- Marc G
you'll either need to open a DAW and have the track active or if your Scarlett has direct monitoring just turn that on
Ahh so I guess that was my stupid mistake? I need Reaper running. I thought the sound would just come through in Windows.
