FS: ART Pro Channel II SOLD
$300 Paypal gift shipped
Shows some signs of wear. Includes original box.
"The ART Pro Channel II™ uses second-generation discrete Class-A microphone preamp to provide clean quiet gain while maintaining incredible transparency. A powerful dynamics processor subtly controls transients and noise of the most demanding sources. The semi-parametric EQ offers wide tune-ability and can be patched before OR after the dynamics processor. Separate rear-mounted insert points allow patching in external signal processing gear immediately after the Mic preamp and before the EQ and dynamics processor. Both analog and LED meters provide a detailed indication of audio levels. Key Features: - Fully Featured discrete class “A” Tube Microphone Preamplifier - 1/4″ High Z input on the front panel - Selectable plate Voltage - Smooth musical sounding Optical Compressor - Separate Attack and Release controls Auto/Manual Attack/Release switch - Parametric EQ Large VU and LED meters - Multi section clip monitor - LED Selectable Source switches for VU signal monitoring of any section of the unit - Two insert loops +4/-10 dB switch for optimal signal output levels - Toroidal power transformer for low noise"
