Page 1 of 6
Amp Stand Builds
Posted: Mon Jun 17, 2013 5:41 pm
by joshatatlasstands
I've been building amp stands out of solid hardwoods for going on three years now. Each build has a build thread that can be used as somewhat of a DIY. If you wanna DIY I'm here to help as well.
Here's the latest completion...Cherry Low Rider with Table Top completed recently.
Here's the build thread:
http://www.atlas-stands.com/index.php/f ... -low-rider
Re: Amp Stand Builds
Posted: Mon Jun 17, 2013 5:50 pm
by Casey4s
Very cool, thanks for posting this
I will probably be building a chassis stand before I build an amp stand. My problem is that I just recently moved from Va to Fl and my woodshop is still not set up and my shop floor is full of temp storage. As soon as I can get my shop back together I wil be looking into building an adjustable chassis stand. I really like the one I saw at your web site.
Posted: Mon Jun 17, 2013 7:34 pm
By all means, check out the chassis stands I've built and feel free to use whatever ideas you like. I like to put a tool tray on the front of them and have both sides slide on the sled, reversible for small chassis too.
Here's are links to some chassis stands you may like:
http://www.atlas-stands.com/index.php/f ... and-cherryhttp://www.atlas-stands.com/index.php/f ... and-walnuthttp://www.atlas-stands.com/index.php/f ... d-chestnuthttp://www.atlas-stands.com/index.php/f ... ching-pairhttp://www.atlas-stands.com/index.php/f ... nd-red-oakhttp://www.atlas-stands.com/index.php/f ... -stand-oakGood luck with the build and let me know if I can assist.
I feel you on the wood shop being full of stuff and torn apart, I have a blown bandsaw motor right now as the bearing decided to blow apart and send metal shavings all through the guts. I'm down for a week or two myself.
Let me know if I can help!
Posted: Mon Jun 17, 2013 9:25 pm
by Casey4s
Thanks a bunch Josh, I really appreciate your kind help and links.
I especially like the one you built for Nathan, that is the basic design I am going to try for in Walnut. Where do you order your hardware from? I like those black knobs and threaded inserts.
Bummer about your band saw going belly up. I hope the repair costs aren't too painful.
Posted: Tue Jun 18, 2013 5:43 am
Thanks, I got the plastic knobs from amazon...1/4" 20 tpi and 2 inches long cut and grind to length. I do it different now though. I make the knobs myself out of a bolt with the head sandwiched between two pieces of wood that are glued together with epoxy. That way the knobs match the stand as well...and it's cheaper:)
One of the build threads has pics of the handmade knobs, and you can make them any shape you want.
Posted: Tue Jun 18, 2013 7:31 am
by Zozobra
Daaaaaiiim. That is some nice stuff you've made! Much nicer than my crummy chassis stand!
Posted: Tue Jun 18, 2013 5:13 pm
made me smile...thank you Sir.
Curly Maple Studio Amp Stand
Seat Width - 14.75 inches
Seat Depth - 13.0 inches
Backrest Width - 13.0 inches
Backrest Height - 15.25 inches
Weight - 12 lbs.
Lift - 9.0 inches @ back of cab
Tilt - 31 deg.
Finish - Danish Oil
This one will have the first "Studio Slip" padded gig bag.
Build Thread:
http://www.atlas-stands.com/index.php/f ... -amp-stand
Posted: Wed Jun 19, 2013 2:52 am
by Elessar [Sly]
http://i56.tinypic.com/so0lz9.gifery cool. The other guitarist in the band is thinking about making one for his amp.
Posted: Wed Jun 19, 2013 6:53 pm
If I can be of any help, please let me know. I'd love to see the work unfold!
Posted: Thu Jun 20, 2013 5:41 am
by Zozobra
I just had a closer look at your chassis stand (I was using my phone before) and its some impressive work. I especially like your take on how to adjust the clamp width for different chassis dimensions. I may have to build a new one now!
Posted: Thu Jun 20, 2013 8:47 pm
Thanks, it's best to let both the left and right side of the chassis stand slide left and right so you don't find yourself working in a corner:) Just my take on the gadget...most have a stationary left or right side. Having both sides moveable also allow you to reverse them for wiring guitar pedals etc.
Eureka.
Posted: Mon Jun 24, 2013 3:09 pm
by KCTigerChief
These are extremely impressive, wow...works of art in their own right.
Posted: Wed Jul 10, 2013 7:46 pm
ty, I'm grateful.
This is the latest off the bench. It's solid African Padauk, built to fit a 3 Monkeys Sock Monkey 1x10 Combo. Yes, that is my AC30 on it, but I won't have images until the owner gets it because I'm not fortunate enough to own a 3 Monkeys Amp…yet.
http://www.atlas-stands.com/index.php/f ... e-backrest
Posted: Wed Jul 17, 2013 5:45 pm
Curly Walnut “Micro” Amp Stand
Build Thread Link :
http://www.atlas-stands.com/index.php/f ... -amp-standTumblr :
http://www.tumblr.com/blog/curlywalnutampstandSeat Width: 14.125”
Seat Depth: 10”
Backrest Width: 12.25”
Backrest Height: 12”
Tilt Angle: 17 Deg.
Amp Lift @ Front: 6”
Weight: 6.5 lbs.
Posted: Wed Jul 17, 2013 6:49 pm
Posted: Thu Jul 18, 2013 7:15 pm
Sassafras and Curly Walnut Low Rider with Guitar Stand for a Marshall 2x12 Combo...Destination New Jersey
Build Thread Link:
http://www.atlas-stands.com/index.php/f ... and-walnutTumblr Link:
http://www.tumblr.com/blog/marshall2x12ampstandSeat Width: 16.75”
Seat Depth: 10”
Backrest Width: 18.5”
Backrest Height: 10”
Tilt Angle: 17 Deg.
Amp Lift @ Front: 7.5”
Weight: 12.5 lbs
Posted: Thu Jul 18, 2013 7:54 pm
by Casey4s
Looks great. You have some very serious photography skills as well.
Posted: Fri Jul 19, 2013 6:50 pm
ty.
SeQuel Tribute Maple Low Rider
Build Thread Link:
to match this:
Posted: Fri Jul 19, 2013 7:33 pm
by Casey4s
You never cease to amaze me Josh.
Posted: Wed Aug 07, 2013 9:01 pm
thanks Casey4s...I throw all I have at it...
Ambrosia Maple Amp Builder/Tech Chassis Stand...ready to go to Nashville.
The latest design change has two reversible and adjustable cradles to fit the narrowest chassis like a guitar effects pedal or home stereo amp.
Build thread:
http://www.atlas-stands.com/index.php/f ... ssis-stand
Posted: Thu Aug 08, 2013 7:16 pm
Mahogany & Curly Maple Atlas "Micro" Amp Stand
Weight: 6.5 lbs
Tilt Angle: 15 deg.
Seat Width: 12 inches
Seat Depth: 10.5 inches
Backrest Width: 9.75 inches
Backrest Height: 14 inches
Amp Lift: 3.5 inches
Build thread:
http://www.atlas-stands.com/index.php/f ... urly-maple
[url=http://s1203.photobucket.com/user/joshatatlasstands/media/pagetall_zpsb9510f5a.jpg.html]
[/url
Posted: Thu Aug 08, 2013 7:17 pm
Posted: Mon Aug 12, 2013 5:25 pm
This is the latest completion heading for the Nashville Amp Expo in a couple of weeks.
It's a solid butternut guitar stand with my old modded late 80's Epi SG, one of my first halfway decent guitars. Great for some Sabbath.
It's made from timber that was downed right here on the property two+ years ago. We thought it was an oak tree when we saw that it was dead and needed to come down, but when we smelled it after the chain saws stopped it smelled a lot like walnut. Sure enough it was butternut, or "white walnut". It's turned out to make some very nice stands since then.
Build Thread:
http://www.atlas-stands.com/index.php/f ... itar-stand
Posted: Mon Aug 12, 2013 6:12 pm
by Casey4s
Great looking work Josh. That SG looks bad-ass too
Posted: Wed Aug 14, 2013 6:35 pm
Thanks, it's pretty tacky and an Epi that's been through 100 different configurations over the years, I learned on it, how to play and how to work on an axe, but I still have it so...
Finished this walnut pedal board this week…
I made it to fit my personal pedal configuration and needs. I'll put my tuner off to the side because I'm not sure what tuner I want to settle on.
It's powered, shielded, and has an on/off switch.
Build Thread:
http://www.atlas-stands.com/index.php/f ... edal-board
