Major league F'n around
Posted: Sat Aug 26, 2023 1:33 pm
by fretless
mod'N the old girl, It originally had a B5 so I went for it and put one back on, plastics off, some new black plastics on the way and knobs. I rotated the magnet in the neck p/u 180 for some outta phase toans. Its crazy cool , a million different tones just by rolling the controls a little, this little test track is just one of many variations, the lead is the outta phase in middle position. the rest is the treble p/u. I freaking love the B5 !!!
sounds like
https://soundcloud.com/fretlessjamz/viridescent
see the mag pulled out :D
Re: Major league F'n around
Posted: Sun Aug 27, 2023 6:16 am
by fretless
Next part arrived, the spoiler. These things are super cool. It makes stringing one easy and it has a straight pull with improved feel due to the new tension. Its smoother and stays in tune better. Must have for you bigsby guys.
Posted: Sun Aug 27, 2023 9:13 am
by screamingdaisy
Always wanted Bigsby on a Les Paul. Because it requires drilling into the top I've never had the balls to do it myself, and because it's worried I'd regret it.
It's kinda like a tattoo, you gotta be committed because it's going to be there for awhile and if you don't like it you're stuck with a bad cover up.
Posted: Sun Aug 27, 2023 9:33 am
screamingdaisy wrote:Always wanted Bigsby on a Les Paul. Because it requires drilling into the top I've never had the balls to do it myself, and because it's worried I'd regret it.
You can use a Vibramate and mount the Bigsby without drilling.
In this guitar's case, I think the previous owner had already drilled for it.
Posted: Sun Aug 27, 2023 9:44 am
by fretless
It was actually a factory install. Special order most likely
Posted: Sun Aug 27, 2023 9:45 am
by fretless
Yeah get a B7 with vibramate. It’s completely reversible with no holes drilled.
Posted: Sun Aug 27, 2023 2:59 pm
fretless wrote:It was actually a factory install. Special order most likely
How do you know that? Do you have the original documentation? I never heard of Norlin doing custom orders but I guess it's possible that they did some.
Posted: Sun Aug 27, 2023 3:07 pm
by fretless
Because the stop tail inserts where never installed. That was done years later and incorrect location.
Posted: Sun Aug 27, 2023 6:52 pm
by Dave
My dad’s LP 50s tribute has a bigsby on a vibramate. Very cool setup
Bigsbys on Les Pauls rule
Posted: Sun Aug 27, 2023 8:28 pm
by greatmutah
Hell yeah man. Looks freakin great. I keep debating putting a Bigsby on my SG. Also, the string spoiler is an absolute must if you don’t have a bar with countersunk holes in it.
Posted: Sun Aug 27, 2023 8:40 pm
:fap: :fap: :fap: :fap: :fap:
Posted: Mon Aug 28, 2023 10:12 pm
by eyeball987
I really like the look of that. Embarrassed to say that I have never played an LP with one before.
Posted: Tue Aug 29, 2023 3:30 am
by fretless
So the real good news for you guys who want to try this is they make a retrofit kit that uses the stud inserts for mounting so no holes need to be added. Mine is different it had the B5 holes already and I couldn’t use the insert holes because they were hand drilled in the wrong location. You want this kit
http://www.vibramate.com/vibramate-v7-lp-install.php
They also do one for the B5 , typically for SG’s and flat tops but yet again another oddity on mine they used a B5. This can cause a overhang on the tail end. On mine its not bad but when installing you must not crank all the screws down or it will bend the unit and cause issues with how it feels.
