Direct mount pickups
Diocide
Post by Diocide »
So my new Balaguer has direct mounted humbuckers.
I found a pickup I want to swap in there but it’s a normal threaded pickup.
Can I just drill the ears out and use it in my direct mount? Is that the only difference?
Re: Direct mount pickups
as long as the pickups have short legs, yes.
I insist on using pickup rings now.
But, yeah, you can just drill them. The only problem is, they'll never work in a normal pickup ring again.
Hipster Salad
Post by Hipster Salad »
I like using something like the FU Tone PMS - Pickup Mounting System. It's a threaded baseplate that you mount the pickup to, with threaded ears. That way you don't have to worry about messing up the wood screw holes in the guitar, and have a consistent mounting base if/when you swap pickups. I feel the FU Tone one is quite overpriced, but over the course of owning whatever guitar you put it in, might not be a big deal - I say that because I could make my own here at my job and the cost to me is literally pennies.
Resident thread killer
I know nothing
Sterling AX40 x3
PRS SE245, SE Paul's
Jet City amps - all of them
modded 2204s
Bogner XTC 3534
Kemper rack
