FS: Ibanez AZ242BC
mystixboi
FS: Ibanez AZ242BC
Post by mystixboi »
Brief & Accurate Description of gear/guitar: Ibanez AZ242BC
Modifications (if any): none
Accessories (hardshell case etc): non-original gig bag - does come with case candy
Location (City,State or City,Country): Cherry Hill, NJ
International OK? : NA
Contact Info (No Phone #s): mystixboi2 @ hotmail.com
References (eBay or other forum userid): ebay - mystixboi
Price (include currency and if firm/obo): $850 paypalled and shipped
Pictures:
here is a full album of pics:
https://imgur.com/gallery/9myUw8V
Up for sale is an Ibanez AZ242BC. The guitar itself is in fantastic condition. A bit of swirl/pic marks between the two pickups, but it's hard to see unless you look at an angle. Also, there is a small bump on the bottom front. I tried to show it in the pics. you can't see it if you look down at the guitar while playing or look straight at it. It doens't have the original ibanez gig bag, but an aftermarket gig bag. It will be well packed when shipped.
Please let me know if you have any questiions. Thanks!!!!
For 2018, Ibanez is introducing a new line of solid body electric guitars called the AZ series. Within that line, we are excited to announce the release of the AZ242BC. Even though Ibanez tends to be a guitar brand associated with modern designs, we have decades of accumulated knowledge and a history to draw from, so pushing boundaries is nothing new for us.
The AZ series carries with it all of the hallmarks of these tried and tested Ibanez qualities: the smooth oval neck profile, the well balanced asymmetrical body shape, and the neck heel allowing unrivaled playability an upper fret access. It also features a new tremolo bridge, as well as newly developed Hyperion pickups, produced in collaboration with Seymour Duncan. All of these elements help the AZ push the existing boundaries of playability and sound to the next level for modern cutting-edge players, while also providing a touch of classic styling.
The AZ’s Roasted Maple neck increases the wood’s stability, durability, water resistance and tolerance of temperature changes. <br>In order to achieve a supremely comfortable neck, the fretboard edge is finished with a smooth curve that extends through the border between the fretboard and the neck to the fretboard itself. The Oval C neck shape allows for a comfortable grip in the lower register, and a more modern feel in the higher register. Luminescent side dots also provide a great point of reference on dark stages.
A shallow rear body contour combines with a larger forearm contour increases player comfort. The pickups, designed in collaboration with Seymour Duncan, are a moderate output pickup, sporting Alnico-5 magnets to keep the clarity of the fundamental tone while using distortion. This design also provides a dynamic and clear pick attack. From treble to bass, the overall tone is evenly balanced and works well with various effects. A newly developed dyna-MIX 10 switching system provides excellent versatility in that it has 10 different possible pickup combinations by way of the mini toggle and 5-way blade switch.
The T1502 bridge is a result of direct collaboration between Ibanez and GOTOH. The narrower string spacing allows for easy picking across strings, for styles such as string skipping and hybrid picking. The snap and hold tremolo arm socket makes it easy to load a tremolo arm, and the arm torque adjuster allows for fine torque adjustments without any tools. The stud lock screws lock the stud bolts in place, for better tuning stability and resonance. The 2-point floating tremolo system creates a super smooth tremolo motion in either direction.
The AZ is also equipped with GOTOH H.A.P-M locking machine heads, which have an established reputation for tuning stability. Its H. A. P (Height Adjustable Post) system allows for the adjustment of string posts to attain appropriate tension on each individual string. Gig bag included.
AZ Oval C Roasted Maple neck
Bocote top/American Basswood body
Roasted Maple fretboard w/Black dot inlay and Luminescent side dot inlay <br>• Jumbo Stainless steel frets <br>• Graph Tech TUSQ nut<br>• Gotoh T1502 tremolo bridge<br>• Seymour Duncan Hyperion (H) neck pickup <br>• Seymour Duncan Hyperion (H) bridge pickup<br>• Gotoh H.A.P-M locking machine heads<br>• dyna-MIX 10 switching system w/Alter switch<br>• Chrome Hardware <br>• Case included <
Features
American Basswood body, Bocote top
Oval C Roasted Maple neck, Roasted Maple fretboard, 24 Jumbo Stainless steel frets
2 Seymour Duncan Alnico-5 Hyperion humbucking pickups, dyna-MIX 10 switching system w/Alter switch
Graph Tech TUSQ nut, Gotoh T1502 tremolo bridge, Gotoh H.A.P-M locking tuners, Chrome Hardware
Specifications Body
Body shape: Double cutaway
Body type: Semi-hollow or chambered body
Body material: Solid wood
Top wood: Bocote
Body wood: Basswood
Body finish: Info not available
Orientation: Right handed
Neck
Neck shape: Oval C
Neck wood: Roasted Maple
Joint: Bolt-on
Scale length: 25.5 in.
Truss rod:
Neck finish:
Fretboard
Material: Roasted Maple
Radius: 15.75 in.
Fret size: Jumbo
Number of frets: 24
Inlays: Dot
Nut width: 1.69 in. (43 mm)
Pickups
Configuration: HH
Neck: Humbucker
Middle:
Bridge: Humbucker
Brand: Seymour Duncan
Active or passive pickups: Passive
Series or parallel: Not applicable
Piezo: No
Active EQ: No
Special electronics: dyna-MIX 10 switching system
Controls
Control layout: Master volume, tone
Pickup switch: 5-way
Coil tap or split: Mini-toggle
Kill switch: No
Hardware
Bridge type: Tremolo/Vibrato
Bridge design: Gotoh T1502
Tailpiece:
Tuning machines: Gotoh locking
Color: Chrome
Other
Number of strings: 6-string
Special features:
Case: Gig bag
Accessories:
Country of origin: Indonesia
The only trades I would consider are another AZ HSS. Thanks!
