deFret
Posted: Mon Jul 15, 2019 8:57 am
by fretless
always start with the last fret , that way if you decide to back out you only screw one fret and not fret #1 on the other end . But some frets are glued in , pressed in or if like Warmoth Epoxied in . If epoxy was used I would not try it , it'll take some serious heat and skill to get them out . But first step is the same , heat them up with a soldering iron to get them moving a little .
I use a knife to get them out , it worked better than any luthier tools I had here . Just work it in down the length of the fret and gently lift out . Apply heat as needed .
go easy , pushing down on the wood around the slot to help keep it from lifting and less fret barb tear out .
one by one and you want to use wood glue on each slot as you go on the tear out , little chips can be saved and glued back in right away , this will save a lot of work later filling any tear out .
so all this is for a fretless conversion , next step here is to cut Maple pieces and glue them in the slots . You'll need to shape the bottom to conform the the cut . Quick and easy here , just has to sit in firmly . I cut and test fit each one before gluing in .
glue in
next is letting dry , rough cutting down then sanding with radius block and finishing .
that's for next weekend .
Re: deFret
Posted: Mon Jul 15, 2019 12:43 pm
by Tortuga
Dayum!!!! Which bass is this for?
Fretless going all fretless and shit :eek:
Re: deFret
Posted: Mon Jul 15, 2019 12:53 pm
by clipless bumper
G-SPACE wrote:Dayum!!!! Which bass is this for?
this must be a clue:
Re: deFret
Posted: Mon Jul 15, 2019 12:57 pm
by fretless
early 90's Bunker PBC bass with floating neck ! I took out the center piece too , it's a odd bass but sounds great .
Re: deFret
Posted: Mon Jul 15, 2019 4:48 pm
by Ostinato Rubato
Look whatever you do just make sure you play in tune mmmmkay
Re: deFret
Posted: Mon Jul 15, 2019 5:30 pm
by fretless
yeah every note of every scale will be played so I would think "in tune " is relevant
Re: deFret
Posted: Wed Jul 17, 2019 6:37 am
by fretless
Just knocked down the big stuff. Next is a little more radius block. I will use Danish oil and fine sandpaper to mix in a sanding dust oil mix to fill it more and build up a few coats and play a thing
Re: deFret
Posted: Wed Jul 17, 2019 8:38 am
by BroSlinger
badass!
Re: deFret
Posted: Wed Jul 17, 2019 8:51 am
by clipless bumper
where did you source the strips of maple that matched the width of the fret slots?
how thick were the strips?
Re: deFret
Posted: Wed Jul 17, 2019 9:03 am
by fretless
Re: deFret
Posted: Wed Jul 17, 2019 11:29 am
by Devin
I wanna see a pic of the whole bass plz
Re: deFret
Posted: Thu Jul 18, 2019 11:01 am
by fretless
yeah should have it back together in another day or so
Re: deFret
Posted: Thu Jul 18, 2019 11:17 am
by SuperFlyinMonke
Devin wrote:I wanna see a pic of the whole bass plz
I think I've only ever seen Fretless post 2 pictures of complete instruments... He artsy.
Re: deFret
Posted: Thu Jul 18, 2019 11:52 am
by fretless
actually I can't ever get the whole thing in frame :idk:
Re: deFret
Posted: Thu Jul 18, 2019 12:47 pm
by SuperFlyinMonke
Do you live in a shoebox? Take a step back.
Really cool project though. I dig it when people care to take pictures and document their DIY shit.
Re: deFret
Posted: Thu Jul 18, 2019 12:51 pm
by fretless
I do with one girl ,2 cats and a fuck ton of music gear , no room
Re: deFret
Posted: Fri Jul 19, 2019 7:22 pm
by fretless
all mistakes were made but the end result is great !
Re: deFret
Posted: Sat Jul 20, 2019 4:48 pm
by Tortuga
Looks fantastic!!!
Re: deFret
Posted: Mon Jul 22, 2019 8:17 am
by fretless
Thanks man ! ok we are done . I took it out to jam and realized the nut action was too high , I knew this was coming so I hit it a few times with a file the first time I put it back together but it needed more after the jam I could tell it was just way to high . So took it apart again , this time photoing the main parts . Remember this is a Bunker "tension free neck" it has a massive center adjustable support that acts as the trussrod , in a hollow and very light weight neck frame . It has a brass nut that the rod goes through and attaches at the butt end like a Fender 3 bolt thingamajig . While apart I did one more radius sanding and it really is super nice now . Sounds very good.
Re: deFret
Posted: Mon Jul 22, 2019 8:34 am
by Devin
That thing is dope af
Re: deFret
Posted: Mon Jul 22, 2019 8:36 am
by fretless
it's a killer little bass . I put the Duncans in it too .She sounds great as a fretless , tons of mmmwah
