FS: Fender American Standard 2015 Ocean Metallic... upgrades
mystixboi1
Post by mystixboi1 »
Up for sale is a killer 2015 American Standard Stratocaster in Ocean Metallic. It is in fantastic condition. It has a few small dings, but nothing major at all. I couldn’t get them to show up in the pics. I’m only selling because I find that I don’t get to play that often so it has to move.
Here is an album full of pics:
https://photos.app.goo.gl/8zF8VGSC1yhc9rHp6
Here are some specs
Series: Standard
Body Material: Alder
Body Finish: Gloss Polyurethane
Neck: Maple, Modern "C" Shape
Neck Finish: Satin Urethane Finish on Back of Neck with Gloss Urethane Headstock Face (Rosewood)
Fingerboard: Maple, 9.5" (241 mm) Radius Frets: 22, Medium Jumbo
Position Inlays: black dots on maple
Scale Length: 25.5" (648 mm)
Nut (Material/Width): Synthetic Bone, 1.685" (42.8 mm)
Hardware: Nickel/Chrome
Bridge: 2-Point Synchronized Tremolo with Bent Steel Saddles
I also upgraded the tuners to Fender Locking Tuners.
Finally, with all due respect to Fender, I found the original pickup config to be boring and lifeless. Thus, I added this set up and the guitar screams!!!
https://920dcustom.com/products/dimarzi ... iser-wp-wh
DiMarzio Andy Timmons Loaded Strat Pickguard DP224F AT-1, DP187 Cruiser WP/WH
All of our items are custom built to order and may require a one to two business day assembly time.
920D Custom Shop Loaded pickguards feature point to point hand soldered connections with Gavitt vintage style cloth wire, CTS 500K split shaft pots, an original CRL 5-way switch, custom cut pickguards, and top quality knobs and buttons. This Andy Timmons pickguard includes a DiMarzio DP224F AT-1 in the bridge position and two DP187 Cruiser bridge pickups in the neck and middle positions. The 4th selector position splits the dual coil humbucker. There is also a treble bleed. This is an "in your face" loaded pickguard.
* DiMarzio DP224F AT-1 Pickups (Bridge)
* DiMarzio DP187 Cruiser Pickups (Neck and Middle)
* 3 Ply 11 Hole Pickguard, White Pearl
* Fender Skirted Knobs, White
* CTS 450G Series 500K Pots
* Original CRL 5 Way Switch
* Gavitt Vintage Style Cloth Wiring
* .022µF Orange Drop Capacitor
* Easy Installation
Switch Positions
1. Bridge
2. Bridge (Inside coil) + Middle
3. Middle
4. Neck + Middle
5. Neck
A player 's player is a perfect description for Andy Timmons. He has great touch, phrasing, and tone. Since 2001, he has been playing a DiMarzio custom bridge humbucker that has only been available on his signature Ibanez guitar, and it has been his first-line pickup ever since. The outstanding characteristics of the DiMarzio AT-1 are balance, warmth, and clarity. It achieves this blend with the same patented technology as the PAF 36th Anniversary but the sound is hotter and the focus is rock.
Tech Talk
The DiMarzio AT-1 was originally designed for a 25 scale but it adapts very well to other instruments. It has enough bass and mids to warm up brighter guitars, and enough clarity for 24 scale set-necks as well.
Specs
Wiring: 4 Conductor
Magnet: Alnico 5
Output mV: 320
DC Resistance: 16.50 K
Year of Introduction: 2001
If you 're a serious traditional Strat player, you probably won 't want to know about pickups with side-by-side coils. But if you 're the player who 's up for something more modern with no 60-cycle hum, string drop-outs or sustain-killing magnet pull, we designed The Cruiser for you. Harmonic overtones are right where you expect them to be from a true single-coil, and the mid-range is open and vocal-sounding. It 's hotter than the traditional single-coil, and the bass strings have a bit more chunk; this is an excellent pickup to combine with medium-output humbuckers, and it maintains its tonal identity with high-gain amps and multiple effects.
Tech Talk
The obvious question about The Cruiser is How does it compare to a single-coil sound? Our feeling is that the unwound strings ( E , B , and G ) are very close, and the wound strings ( D , A , and low E ) are fatter-sounding than a true single-coil. There's also a midrange scoop that's unique to the Cruiser Bridge. This is really effective for getting big-sounding chords, because high and low strings sound more spread out from each other. Having a total magnet pull that's about 40% less than standard single-coils also means The Cruiser can be adjusted much closer to the strings for more power than stock pickups can achieve.
Specs
Wiring: 4 Conductor
Magnet: Ceramic
Output mV: 143
DC Resistance: 5.75K ohm
Year of Introduction: 1994
Finally… since I’m an Andy Timmons fan, I brought it to me to one of his recent concerts in Philly and I had him sign the back of the headstock!
I'm looking for $925 shipped in the continental US. It also comes with OHSC.
Please let me know if you have any questions. Thanks!!!
Main Guitars:
PRS CU22
Ibanez Andy Timmons
Yamaha Revstar RS502
Fender Deluxe Player’s strat
EVH 5150 iii 50 watt
Boss Katana
My music:
www.johnmendozamusic.com
