7 String OFR Replacement Blocks
Posted: Sun Sep 24, 2017 3:53 pm
by maggotspawn
Replaced my LO TRS in my RG7420. Seemed to fit perfectly, until I went to put the cavity cover back on. The block is just a hair too tall. I still have to measure the block, but Floyd Upgrades has 7 string brass blocks. I think the 34mm one is the one I need. Anybody run across this problem? Does anybody know where else to get 7 string OFR replacement blocks?
Re: 7 String OFR Replacement Blocks
Posted: Sun Sep 24, 2017 4:45 pm
by EndTime
You have a bench grinder?
Hell anything that can grind. Maybe even a dremel with a grinding attachment would get you there, albeit, perhaps a little sloppy depending on your skills.
But yes, I've had numerous blocks not fit and just used my bench grinder to take em down to the right depth
Posted: Sun Sep 24, 2017 4:54 pm
by maggotspawn
My OCD won't let me do that, plus I don't have a bench grinder. I could get an angle grinder and do it that way, but again the OCD thing. I think the 6 string and 7 string blocks are the same. Floyd Rose sells a granite block and it's supposed to fit either trem.
I'll call them tomorrow just to make sure.
Posted: Sun Sep 24, 2017 5:35 pm
by maggotspawn
It seems the 6 and 7 string OFR's take the same block. Ordered on for $20 shipped.
Cheaper and less hassle then getting a grinder.
