My Epi LP Ultra ll has the controls on a circuit board. I know normal ones can be rewired, but mine has the piezo pu at the neck and 2 inputs. Has anyone rewired these ??
nice job, billy
Rewire LP
Re: Rewire LP
Uggg. i hate those circuit boards.
That is a guitar that would come into my shop (with the piezo), asked to be re-wired and i'd say... uhhhhhhhhh. I'm a guitar tech, not an electrical engineer
How do you want to rewire it? Is the piezo board part of the main board? Usually i'd start with ripping everything out and just wiring it up with new switch and pots, but the piezo part, if it is on the main board, would obviously cause an issue there. If it's on it's own board, it should be fairly simple.
edit: found this
edit: found this
My metal band, Contrarian
Friedman BE100
Marshall JCM800 1987
Helix Floor
Friedman BE100
Helix Floor
Re: Rewire LP
Yeah, the pre amp and everything on one board. I just wanted to upgrade pots, ect...
"Madison Square Basement !!!!"
Re: Rewire LP
kissmyace wrote:Yeah, the pre amp and everything on one board. I just wanted to upgrade pots, ect...
The diagram there should do it for ya.
Friedman BE100
Helix Floor
Friedman BE100
Helix Floor
- Ancient Mariner
- New Member
Re: Rewire LP
That's a good diagram. I'd really liked to have rewired my xtSA and replaced the pickups, but it can't happen witout removing synth control, and that's the main reason for keeping that guitar.
Re: Rewire LP
I doubt u will notice enough of a difference in switching all the wiring/pots to justify the money and time needed, especially being its not a standard lp type hookup with the piezo etc. especially if you aren't changing values and just putting different brand pots or caps.
