Page 1 of 2
Marshall JVM410 Mods
Posted: Sat Apr 09, 2016 12:05 pm
by TTBull
Re: Marshall JVM410 Mods
Posted: Sat Apr 09, 2016 1:08 pm
by III
Will definitely look into these mods... such a horribly noisey amp.
Posted: Sat Apr 09, 2016 1:14 pm
by Tortuga
Wow - very interesting...
I don't suppose you have recommendations for similar improvements on the current-model DSL100H?
Posted: Sat Apr 09, 2016 1:22 pm
by TTBull
Posted: Sat Apr 09, 2016 1:24 pm
by Tortuga
Awesome! :drool:
:welcome: to the board (if I haven't already said so before). This is a hell of a good way to start!
Posted: Sat Apr 09, 2016 1:27 pm
by TTBull
Posted: Sat Apr 09, 2016 1:31 pm
by Tortuga
Well, it sure violates something :thu:
Looks awesome - is it DIY or bought?
Posted: Sat Apr 09, 2016 1:32 pm
by TTBull
Posted: Sat Apr 09, 2016 1:36 pm
by Tortuga
Wow - great job on that!
What did you use? I want to have my kids do some artwork on cloth for my studio (obviously the content would be a bit more tame :D ), and I need some kind of acoustically-transparent way of letting them go at it - this looks perfect!
Posted: Sat Apr 09, 2016 1:44 pm
by TTBull
Posted: Sat Apr 09, 2016 2:03 pm
by shane159
I put a 10 H choke on the 410 that I owned and it killed a good bit of the noise also. Curious to see what you come up with. Welcome!
Posted: Sat Apr 09, 2016 4:51 pm
by TTBull
Posted: Sat Apr 09, 2016 5:09 pm
by TTBull
Posted: Sun Apr 10, 2016 1:24 pm
by TTBull
Posted: Mon Apr 11, 2016 6:05 am
by neilrocks25
nice mods, mine was modded by Dan Gower and with a few mods you can change the amp from good to great. Mine sounds so open. there is a slight noise but the gain reduction mod can help with that.
Posted: Mon Apr 11, 2016 1:12 pm
by TTBull
Posted: Fri Apr 15, 2016 5:39 am
by TTBull
Posted: Fri Apr 15, 2016 7:09 am
by neilrocks25
TTBull wrote:Image
This will fully kill all the floor noise in...all the high gain modes in the amp
this is the peavey JSX noise gate....works great for the jvm410.
Edit: ill have some pics of this installed shortly
Ineresting
Posted: Tue Oct 11, 2016 12:34 pm
by TTBull
Posted: Fri Nov 04, 2016 12:07 am
by hadley101
Aw man, didn't get TTBull's mods for this amp, have
a JVM210h on the way and thought this post wasn't
going anywhere and didn't think to write them down.
He is the only person to address the noise these amps
make in the overdrive Orange/Red channels, the JVM
forum has ZERO on this problem.
Did remember he said the Plates and some resistors to ground
were carbon film and there is drift as well due to them.
Also he said that he preferred a certain type of metal film,
PRP and Caddock.
Anyone else happen to get the resistors written down? Promise
won't share or post anywhere else, as sure TTBull pulled the post
as not to share valuable information too broadly.
Posted: Fri Nov 04, 2016 1:04 am
by shane159
Why did he pull his post?
Posted: Fri Nov 04, 2016 1:08 am
by shane159
hadley101 wrote:Aw man, didn't get TTBull's mods for this amp, have
PRP and Caddock.
The choke mod helps the noise, but it's still unfortunately a noisy amp. I had two and did almost all of the JVM forum mods, and a JCM800 with a boost sounds much better.
Posted: Fri Nov 04, 2016 1:17 am
by Tortuga
What happened to all TTBull's postings? :(
Posted: Fri Nov 04, 2016 10:31 am
by hadley101
Maybe hosting the pictures is a problem
Also his work is very unique and significant
for the JVM, probably wishes not to give his work
away.
No one else has this kind of mod for the JVM
other than the Mod shops, ie. Voodoo mentions
lowering noise in their standard mod
Hopefully someone in the forum was able to save the
page or write down the resistors, he also had a few
mods that aren't in circulation at the JVM forum.
Learned my lesson the painful way, usually the only
way that actually learns me good. :facepalm:
Posted: Fri Nov 04, 2016 10:37 am
by Zozobra
