I have looked at cable and plugs from GFS, Lava Cable, George L, Wilde Pickups, and Planet Waves kits. I love the size of the George L, Lava Cable, and Wilde Pickups [though it doesn't appear they have R/A] plugs. Based off of what I have seen, the Lava Cable and George L seem like they would be the most durable. The Planet Waves and GFS have a lot large plugs. This could be an issue if I were to use R/A at my switcher, since the loop in/out jacks are fairly close together. I have seen this unit wired up with either George L or Lava Cable R/A and they seemed to fit together meticulously.
That being said, I am being cheap, and want to get the best bang for my buck. I will need to make 14 cables and I want to stretch my money the most appropriately. I have this fear that the solderless kits could be problematic for conductivity/durability in the long run and I would be better off just using solder plugs...
Can any of you give the rundown on any of the manufacturers and which would be the best way to go. Also, any insight on the solderless setup in general would be greatly appreciated.
Thanks
