True bypass loopers
Posted: Sat Feb 16, 2013 10:58 pm
by NaturalBornBoy
Can you use just one true bypass looper if you have pedals that are both in front of the amp and in the fx loop?
Or do you need 2? One for the pedals in front and one for the pedals in the loop?
Re: True bypass loopers
Posted: Sat Feb 16, 2013 11:25 pm
by primeholy
We need a true effects forum for a proper answer. I have two loopers(m13 and jam man stereo) but I dont use either.
Posted: Sat Feb 16, 2013 11:29 pm
by NaturalBornBoy
I don't mean loopers like the Boss RC-3 kinda looper.
I mean these kinda loopers.
Posted: Sat Feb 16, 2013 11:51 pm
by primeholy
NaturalBornBoy wrote:I don't mean loopers like the Boss RC-3 kinda looper.
Fuuuuuuuuuuuuu
Posted: Sun Feb 17, 2013 12:02 am
by Micter
You would need two.
Posted: Sun Feb 17, 2013 12:07 am
by colejustesen
I think you would need to get two of those particular units... I have a Carl Martin Octa-Switch that allows you to use one unit both for pedals up front and in the loop... It is a matter of using one of the loop in/outs to send to the effects loop/amp input... everything before it goes in the front and everything after goes in the loop. I have it setup so there are 3 loops that go into the front and 4 that go into the loop. I have set it up so that each loop contains one pedal. Since the Octa-Switch allows you to choose which loops to be on at the same time, I can get 8 different presets to work with...
This image might make more sense that me typing it out...
If you have a single channel amp this unit is amazing! If you have a channel switcher the latest version would work best [as long as you can change channels via 1/4" mono plug], that is the MkII. The one in the picture is the MkI unit, which is what I have.
Posted: Sun Feb 17, 2013 6:31 am
by NaturalBornBoy
Yeah I sorta guessed that I would need 2 of 'em.
The Octa Switch takes up a whole lotta space.
Posted: Sun Feb 17, 2013 7:24 am
by vickno
As far as I know you can do it with the Voodoolab, RJM, Musicom Lab and maybe there are more, check out this:
http://www.loopersparadise.de/
Posted: Sun Feb 17, 2013 7:42 am
by NaturalBornBoy
I just want a simple, non-programmable, TBL.
I don't want to get into the RJM stuff.
Posted: Sun Feb 17, 2013 7:46 am
by NaturalBornBoy
I was thinking that it would be easier if I could get away with using just one, 8-loop, switcher but I don't know if I'll run into any ground loop issues.
Posted: Sun Feb 17, 2013 8:44 am
by Macelind
NaturalBornBoy wrote:I just want a simple, non-programmable, TBL.
They are REALLY simple to build. All you need is an enclosure, 1/4" jacks, and DPDT switch.
Posted: Sun Feb 17, 2013 11:19 am
by Cirrus
You could use one just fine, but if its only send /return on each loop as most are you basically put your amp's preamp in one of the bypass loops and leave it always on, then plug the end of the looper into the fx return of your amp.
Posted: Sun Feb 17, 2013 1:27 pm
by macgaj3
And with a standard loopmaster style you only have one input and one output. So you technically could split it in two by using the send jack of one loop to go to the front of the amp and bring in your effects loop to the return.
Hitting that loop would mute your whole rig too.
Edit - too slow
