Warm audio - wa76 comp
Posted: Sat Feb 14, 2015 9:12 am
by BroSlinger
It's a comp. should I get one?
Re: Warm audio - wa76 comp
Posted: Sat Feb 14, 2015 9:13 am
by TurboPablo
No, because then I will have to follow suit and I just can't afford it.
Posted: Sat Feb 14, 2015 9:20 am
by newholland
I know its a relatively impertinent question.. But why d you need onefor guitar recording? I'd like two for mixing... But I can't figure a need for recording.
Posted: Sat Feb 14, 2015 9:25 am
by TurboPablo
Yay!!!
Thank you for crushing my dirty thoughts.
Posted: Sat Feb 14, 2015 9:38 am
by BroSlinger
Dammit. Guess I don't need it
Posted: Sat Feb 14, 2015 9:59 am
by newholland
BroSlinger wrote:Dammit. Guess I don't need it
don't you always use a comp gene? where are you using the CAD-- is that only for mixing?
not to crush any wishes..
i LOVE the idea of having something made by a company i really like that sounds really good.. but i do okay with VST's honestly-- at least for compressors.. but it's been YEARS since i used hardware comps, and i surely never had high class biz like an 1176 lying around, real or otherwise. mostly dbxes.
Posted: Sat Feb 14, 2015 10:01 am
by nightflameauto
Guitar recording? No. Bass recording? Yes.
I'm a helper. I'm helping.
Posted: Sat Feb 14, 2015 10:05 am
by TurboPablo
I use a Sans Amp for bass.
Rather, I have a Sans Amp that I am finally using for bass.
Posted: Sat Feb 14, 2015 10:06 am
by newholland
nightflameauto wrote:Guitar recording? No. Bass recording? Yes.
yeah.. but $600 for a single channel comp to record bass when a guy records mostly synth, guitar, drum machine, and no vocals?
hrmph. i love good gear. but most of that comp work's gonna be stereo or unnecessary. so if you're gonna help, you gotta pitch for two.
two or none, gene. two or none.
i personally would like two wa12's and two wa76s. but that will probably never happen.
Posted: Sat Feb 14, 2015 10:07 am
by TurboPablo
Buy EZDrummer2 instead
Be the drummer Broslinga.
Posted: Sat Feb 14, 2015 10:15 am
by nightflameauto
newholland wrote:nightflameauto wrote:Guitar recording? No. Bass recording? Yes.
I'm nightflameauto and I approve this message.
Posted: Sat Feb 14, 2015 10:17 am
by TurboPablo
If I like the WA-12 as much as I think and hope I do, I could see getting another. My interface has two inputs. So it makes perfect sense to me.
I will most certainly grab another Fathead Mic in the next couple of months.
Posted: Sat Feb 14, 2015 10:21 am
by newholland
i am a firm supporter of buying recording gear in twos. if i was meant to buy in ones i would have one ear in the middle of my forehead.
nobody wants an ear in the middle of their forehead.
Posted: Sat Feb 14, 2015 10:22 am
by TurboPablo
I agree.
But my wallet has issues.
Posted: Sat Feb 14, 2015 10:28 am
by newholland
well. there's that.
even still.. i plot trajectories in twos.
i bought one wa12. but another.. it's coming. oh yes it is.
Posted: Sat Feb 14, 2015 10:56 am
by BroSlinger
newholland wrote:BroSlinger wrote:Dammit. Guess I don't need it
Yeah, I use the hardware comp for everything.
Chain goes :
1. Wa-12 preamp
2. Cad compressor
3. Tc 1128 eq
4. Roland rsp-550 reverb
5. Focusrite Scarlett 2i2
I use that hardware for everything. Bass, guitar, drums, etc.
Posted: Sat Feb 14, 2015 1:04 pm
by Markdude
I think one would be awesome for mixing (routing tracks through it and printing new ones). But IIRC you guys are using the 2i2 and the Blackjack, so unfortunately you don't have enough outputs to really facilitate that.
For tracking I think it would be a good investment for a little bit of compression on the way in for bass. If drums and vocals, definitely a worthwhile purchase. For just recording guitars? It's just GAS, man. Not really gonna help all that much. If anything maybe Gene would get some mileage out of it since he does dreamy clean stuff most of the time, but I know Pablo likes cranked Marshalls. For recording overdriven stuff there's really not much point since you generally need little to no compression and software is adequate anyway. Hardware compression really only has much of an advantage for highly dynamic sources with big transients, like drums.
Posted: Sat Feb 14, 2015 1:17 pm
I use a compressor pedal when recording clean guitar or clean slide guitar for sustain with a mic'd amp.
When I record direct guitar the sims provide the compression or, if needed I can add a compressor plugin.
I have a Really Nice Compressor in my lunch box but, I only use it for vocals.
It's kind of overkill on guitar, especially when using a compressor pedal or sims.
That being said... if I wanted to try something different, like recording clean and direct, without sims, a compressor out front would be helpful.... but again, a pedal would work.
