Which Floyd Rose's have the free swinging arm?
Posted: Wed Feb 06, 2013 1:35 pm
by ledvedder
I'm trying to sort through all the Floyd's that are available. Which ones have the free swinging arm instead of the arm that screws in and gets tight at a certain point?
Re: Which Floyd Rose's have the free swinging arm?
Posted: Wed Feb 06, 2013 1:47 pm
by clipless bumper
Those are the snap-in arms, right?
I just picked up a Yamaha Pacifica 921 with a RM ProII that has that type arm.
When I was researching where to find the arm - I saw that the Ibanez Edge Trems also had the same arm.
Posted: Wed Feb 06, 2013 2:10 pm
by fretless
only the early 80's OFR's have the "screw in" arm , later 80's and all of the current FR's have a "collar" arm and those swing free unless you tighten that collar down . Though the screw in swings free too unless it's at the last thread .
Posted: Wed Feb 06, 2013 4:18 pm
by Rampage
fretless wrote:only the early 80's OFR's have the "screw in" arm , later 80's and all of the current FR's have a "collar" arm and those swing free unless you tighten that collar down . Though the screw in swings free too unless it's at the last thread .
This.
The Edge on my old RG550 was the only Floyd-like trem that had an arm that didn't want to swing around.
Posted: Wed Feb 06, 2013 4:21 pm
by thefyn
All of them after 2 fucking months!!!
I always break the collar somehow. (Keith Stone voice) "Always"
Posted: Wed Feb 06, 2013 4:26 pm
by facefirst
The Floyds that only lock at the nut have the pop in arm. I used to have an Ibanez RG350 (or something like that) that had that kind of arm.
Posted: Wed Feb 06, 2013 4:29 pm
by ledvedder
Posted: Wed Feb 06, 2013 4:45 pm
by fretless
all 3 have different arms , The "1984" has the original screw in , which many prefer and btw the arm socket thingie is replaceable on a OFR so you can swap either the collar or screw in part , into the baseplate .
That Gotoh has a push in type with a tension screw
the last FR at MF has the collar type
Posted: Wed Feb 06, 2013 4:53 pm
by facefirst
That 1984 one is priced pretty decent considering it has upgraded fine tuners and a big brass block. I put a big brass block on my San Dimas FR and it's a night and day difference.
Posted: Wed Feb 06, 2013 5:27 pm
by ledvedder
facefirst wrote:That 1984 one is priced pretty decent considering it has upgraded fine tuners and a big brass block. I put a big brass block on my San Dimas FR and it's a night and day difference.
Now, that has a screw in arm? Or can you adjust the tension?
Posted: Wed Feb 06, 2013 5:42 pm
by fretless
The screw in tension is set up like this .. it has an adjustable piece with a washer under the baseplate , you screw the arm all the way in then you turn that piece on the bottom for how much tension you want . I set it very tight and spin back the arm 1 or 2 threads , then with a spin forward it will sit right where you adjusted it to . The collar version works well too , you just need to spin that or adjust it during regular play .
Posted: Wed Feb 06, 2013 5:53 pm
by Edgeofdarkness
my early 90's Jackson custom has screw in arm.
Posted: Wed Feb 06, 2013 5:59 pm
by gb74
thefyn wrote:All of them after 2 fucking months!!!
lol this
