Sh*t!!! Interface Won't Work!
Posted: Sat Jan 25, 2014 11:30 pm
by JerEvil
Upgraded to OS X 10.9 only to find out Focusrite's software for Saffire Pro 24 only supports up to 10.8!
Aaarrgh! Wat do?
Re: Sh*t!!! Interface Won't Work!
Posted: Sat Jan 25, 2014 11:33 pm
by ovid9
Downgrade back to 10.8?
Posted: Sun Jan 26, 2014 12:14 am
by JerEvil
ovid9 wrote:Downgrade back to 10.8?
No install for 10.8. Had 10.7 which won't run Logic Pro X.
Posted: Sun Jan 26, 2014 12:30 am
by Markdude
I'm a PC dude, but you might want to do some searching and see if "Asio4All" (or something similar) is available for Mac. It's a generic set of low-latency drivers that should work with most interfaces. Other than that, maybe dig deep into your interface's manufacturer's website and see if there's a beta drivers section. Those might support newer operating systems. For instance, my EMU 0404 USB (my favorite budget interface) is pretty old and it actually doesn't have any official drivers for Windows 7, but they made a beta driver for W7 before they discontinued the interface, and that driver works fine for me.
Posted: Sun Jan 26, 2014 1:21 am
by JerEvil
Markdude wrote:I'm a PC dude, but you might want to do some searching and see if "Asio4All" (or something similar) is available for Mac. It's a generic set of low-latency drivers that should work with most interfaces. Other than that, maybe dig deep into your interface's manufacturer's website and see if there's a beta drivers section. Those might support newer operating systems. For instance, my EMU 0404 USB (my favorite budget interface) is pretty old and it actually doesn't have any official drivers for Windows 7, but they made a beta driver for W7 before they discontinued the interface, and that driver works fine for me.
They only make it for PC. Focusrite is aware of the issue it seems and they are working on it ... supposedly.
Posted: Sun Jan 26, 2014 7:32 am
by Sizzler
Posted: Sun Jan 26, 2014 3:21 pm
by JerEvil
No on the fusion drive on my iMac. Standard SATA drive
Posted: Sun Jan 26, 2014 8:29 pm
by Sizzler
Damn - are you getting and sound then it cuts out or is it bit recognizing the interface at all?
Posted: Sun Jan 26, 2014 9:08 pm
by JerEvil
pamukParty wrote:Damn - are you getting and sound then it cuts out or is it bit recognizing the interface at all?
Not recognizing it at all. When I launch the Saffire Mix Control software (which seems to be required) it tells me "No device connected"
Posted: Mon Jan 27, 2014 9:39 am
by Sizzler
Any ETA from Focusrite on a fix? - now this does sound like their problem.
Wonder if there's a cheaper interface that you could pick up to use in the meantime that is confirmed to work with Mavericks.
Posted: Mon Jan 27, 2014 9:54 am
by nightflameauto
Wait, something ain't right on your setup if you always had to run mix control to get your Saffire recognized. My Saffire Pro 24 is always available in audio devices whether mix control is running or not. If you go Apps->Utilities->Audio Devices and check and see if it's listed in there. One of the things I had happen during an OS upgrade on my system was it reassigned everything on the USB and Firewire buses so it ended up grabbing hold of the "old" assignment and giving me a dead device as my default. I went in, turned the default devices all back to built in, rebooted, then reset everything to the Saffire again and it was fine.
I won't say that'll fix what you have going on for sure, but it's worth a shot.
Posted: Tue Jan 28, 2014 10:46 pm
by JerEvil
It's alive ...ALIVE!!!
Did a hard shut down after trashing and reinstalling the newest version of mix control. Unhooked everything and did a full restart. Launched mix control THEN fired up the Saffire.
Mix Control did another firmware update and voila! Metal a-go-go
Fucking phew!
Posted: Wed Jan 29, 2014 9:40 am
by Sizzler
Sweet!
Glad you got it worked out man.
