Incoming NAD
_ej_
Re: Incoming NAD
Post by _ej_ »
I wonder what the B+ voltage is. I had a Silver Jubilee that Ryan built back in the day. He specifically lowered the B+ voltage to tame the volume and it was exactly like you described.
Re: Incoming NAD
I had the same Jubilee on loan for a while. Yes it was kinda similar although this is even quieter than Ryan's Jubilee. If that's the issue it will be an easy fix.
I think it's indeed something along those lines since the amp sounds great aside from the low volume, so I don't think there is something seriously wrong with it. But I don't want to take chances.
Re: Incoming NAD
Don't suppose you snapped a hi res gutshot? It could just be shitty soldering somewhere, or they may have modded it to cut volume? You'd hope they'd mention something like that though :lol: Accidentally using the wrong bias resitor in the PI will absolutely neuter the volume.
Re: Incoming NAD
Zozobra wrote:Don't suppose you snapped a hi res gutshot? It could just be shitty soldering somewhere, or they may have modded it to cut volume? You'd hope they'd mention something like that though :lol: Accidentally using the wrong bias resitor in the PI will absolutely neuter the volume.
Unfortunately I didn't. It's at the shop now so let's see what my tech says.
Re: Incoming NAD
It would sound like sizzling dicks if the OT was damaged, so it's probably just something dumband easy to fix. Here's hoping anyway.
