JCA to SLO mod for 22H, 50H, 100H
Re: JCA to SLO mod for 22H, 50H, 100H
Any chance of posting one of these for the 20H?
- neilrocks25
facefirst wrote:Any chance of posting one of these for the 20H?
Please
Pretty please?
The 20H has 3 gain stages and a cathode follower, the SLO/22H/50H/100H has 4 gain stages and the cathode follower. You would need to jam another tube in there somehow. I'm sure there's other things to do on the 20H.
Loud Noises
I think there is one thing missing from your list.
SLO has a 47pF fizz cap. JCA 50/100H has a 120pF.
Correct me if i'm wrong. Other than that its spot on!
Anyone have the details for the clean/crunch switch?
Does the SLO mod remove some of the fizz?
If not could somone tell me how to go about maybe reducing the fizz?
You can always use a MOSFET for the follower driving the tone stack
- New Member
So anybody have a SLO Clean / Crunch schematic numbered for the 22H to go along with this? Some decent pics of one wired up would be great as well. Thanks!
here is a picture with values if you havent already seen it. i am currently modding the same amp. the slo100 mods for the other jca models are going to be the same for the 22h. check out my thread on ithe jca22h. i would suggest some different mods than the slo100 mods.
Nevermind figured it out.
Thanks for the schematic with values you posted earlier shep.
no problem
Hi all
I would like to share my (little) experience with modding my JCA100H
Depth mod - Great addition to this amp and very easy to do !
SLO100 lead preamp mod - This mod is the swap of a resistor, 2 caps and the gain pot (1M to 500K).
I did and... probably better than stock but it is not OMG.
The OD channel is louder than before with still tons of muddy bass.
Swap of coupling cap after V2a (0.02 --> 0.002 uF) + swap of R36 (1M to 470K).
Gain pot is more usable and the lead channel is less bassy/muddy. More marshall raw tone.
Slope resistor into tonestack: i have added a DPDT switch to choose between stock (47K) and 68K.
68K is nice, kind of modern sounding scooped style.
And it makes the whole amp quieter, allowing to push master a little more, which is a good thing.
Remove the bypass cap C19 on the cathode follower. This will help to "clear up" both channels: the clean will stay CLEAN up to 4 on gain (depending on pickups) and the lead gain will be more usable, less fizzy/boomy, allowing to dial extreme settings (8-9). Such an easy mod !
Have fun !
Have fun !
"Remove the bypass cap C19"
Just did this on my JCA50 and it definitely took a lot of the haze off. Nice one thanks!
Jay - I don't believe this question ever got answered....
Is this the correct capacitor, and should that value be changed?
Also, what's the final verdict on changing the gain pots to 500k? Necessary or not worth the effort?
liam5150 wrote:I think there is one thing missing from your list.
- Bassman overhaul - G-MAN
Changing the gain pots definitely make them more usable and got rid of the muddiness after 7ish on the dial. Have to change the 2 caps and 2 resistors as well but very noticeable when I did it to my 50H and my old 100H.
Resident thread killer
I know nothing
Sterling AX40 x3
PRS SE245, SE Paul's
Jet City amps - all of them
modded 2204s
Bogner XTC 3534
Kemper rack
I know nothing
Sterling AX40 x3
modded 2204s
Bogner XTC 3534
Kemper rack
I've been learning a ton about amp theory for a Fender rebuild I'm starting, and decided to see how it applied to the JCA schematics that I was barely familiar with. Making tons more sense now, especially in how tube gain is established with the various resistors, filters, DC blocking caps, etc. Re-read pretty much the entire 28 pages of the JCA thread yesterday and make a ton of reference updates, including to this thread. Now this mod doesn't seem so daunting, and I'm seriously considering doing it. Thanks for the update on the pots (I do remember you stating that it did seem to help) - now I just want to know for sure about the fizz cap.
Not sure what capacitors I'm going with for this. Might get really crazy and upgrade a bunch of 'em, since there's been quite a few people (midnightlaundry, Kasbrot, and others) stating they had a major improvement in performance and tone from just doing that.
GRIMESPACE wrote:Jay - I don't believe this question ever got answered....liam5150 wrote:I think there is one thing missing from your list.
Which one is the fizz cap on the board?
I know nothing
Sterling AX40 x3
modded 2204s
Bogner XTC 3534
Kemper rack
I know nothing
Sterling AX40 x3
modded 2204s
Bogner XTC 3534
Kemper rack
The 120p cap in that figure should be shown as being connected between the plates of the V5. It's purpose is to stabilise the the negative feedback loop although there are better ways to do this. It isn't a fizz cap.
There are a few drawing errors on that schem. The big one is that one of the PI plates isn't connected as an output to the power tubes!
Don't forget to swap the OT for an Onetics. I believe it's the hi-def. C3amps calls it the SLO OT.
A - A
Hipster Salad wrote:Here are the pots you will need as well -
Two 500k PC mount 16mm (mini) audio/log:
http://www.newoldsounds.com/index.php?m ... s_id=11305
Exact drop in replacement, and actually the shafts are better quality IMO because they aren't split or prone to breaking off.
Sorry to quote an old post but that link is dead and I'm currently putting together an order for some mods. It sounds like the perfect replacement though. Currently trying to cover all bases in one mouser order. Can anyone suggest a hassle free drop in mouser carries. Plan on starting with the depth mod but I figured I would just reuse the removed 1M pot during the SLO mod (ideal stolen from much board reading....)
Need to stay off this board while I'm waiting on new tubes to arrive.
Guitars
Cimar Acoustic MIJ
Epiphone Ltd Ed LP Custom Silver Burst MIC 2018
ESP Hybrid II Seafoam Green MIJ 1990
ESP/LTD EC-401vf Faded Cherry Sunburst MIC
Fernandes Telecaster MIJ
Ibanez Artist AR-30 MIJ Black 1983
Ibanez Artist AR-200 MIK Trans Red 1998
Ibanez Artist AR-200 MIC Gold 2013
Ibanez Iceman IC-300 Black MIK
Ibanez S470DXQM MIK 2009
Schecter Tempest Custom Black
Squier Stagemaster v1 Blue Floyd Rose
Yamaha Classical
Yamaha Pacifica MIK
Blackstar HT-40
Fender Blackface Bandmaster 1966 (project)
Jet City JCA-50
Mesa Boogie DC-5b w/vol mod & series loop mod
Fender 2x12 Bandmaster Cab 1966
Mesa Boogie 2x12 w/Black Shadow C90's
Pedals
30ish
Pedaltrain Pro (holds some...}
Cimar Acoustic MIJ
Yamaha Classical
Yamaha Pacifica MIK
Blackstar HT-40
Jet City JCA-50
Pedals
30ish
Change C10 and C11 (22n) to 47n
This is the single best mod I did to this thing.. It lets the lowend through and beefs and balances out the tone..
I'll start by imparting my effortless polarization by virtue of participation..
