Re: Staining a headshell
Posted: Tue Mar 15, 2016 2:12 pm
Don't you want to go finer AFTER staining for a final finish?
A Forum for Gear and Music Enthusiasts
https://guitarampboard.com/
EndTime wrote:Holy-diver wrote:what grits should i buy, im planning on using an oil based stain and i was thinking down to like 200, but whats a good progression?
Depending on how much sanding is necessary. If yo ucan start at 120, then start there. Do 120, 180 and maybe 220 if you want.. But 180, or even 150 should be fine as a final grit if it was sanded by hand.. Any smoother than 220 and you are essentially polishing the wood which is closing the grain more and more and prevents stain from penetrating and absorbing evenly.. Especially maple.. For guitars I generally sand maple to 220 and it works well.. But again, thats using dyes.. For typical Minwax oil stains, its not necessary to sand it glass smooth before you stain.. Like I mentioned its closing the grain and for a wood like maple to take stain evenly(which it really doesnt) you ideally want the grain to be open.. Which is either sanding up to 150, or "popping the grain" if you wanted to go real dark like Ebony..
YOu wouldnt sand the stain./ After its stain, you start the coating process. You would sand the finish between coats which you can go finer, but honestly anything beyond 220 is essentially overkill for a typical oil or waterbase finish you would find at Menards or Depot..mamberg wrote:Don't you want to go finer AFTER staining for a final finish?
JerEvil wrote:EndTime wrote:Holy-diver wrote:what grits should i buy, im planning on using an oil based stain and i was thinking down to like 200, but whats a good progression?
Ok so let me make sure I am understanding what I think the basic process would be.
1. Use spray bottle with water to wet the wood
2. When dry, sand with 120
3. Spray with water again
4. Sand with maybe 150?
5. Apply dye as desired, wiping excess off and let dry
is that about right? Is something like a spray shellac ok? Maybe 3 or 4 coats and then super fine hand sand?
EndTime wrote:JerEvil wrote:EndTime wrote:Holy-diver wrote:what grits should i buy, im planning on using an oil based stain and i was thinking down to like 200, but whats a good progression?
If you are going to use a dye, then I would probably go to 220 and NOT pop the grain with water.. Dye is different than stain.. Stain is penetrating the wood, dye is more or less dyeing the wood.. So thats why I dont sand wood too fine when using stain..
For dye, 220 grit with an alcohol or water base dye is usually pretty good for me..
So just start sanding with 120 or 150(whatever is necessary) 180 then final with 220.. Then go ahead with your dye..
Shellac is a great sealer, but its not really a hard final coat. So I wouldnt recommend it for a headshell. YOu can use shellac under a water or oil-base finish tho.. But I think for the color you want I would use a waterbase spray poly.. Minwax has the Polycrylic stuff.. The reason why is, oil base finish yellows over time. Which over grey isnt all that great looking.. Shellac doesnt yellow over time, but it has a golden tone to it that over a black or grey finish will show a bit of yellow. Waterbases are clear.. Plus they are very hard. Quick drying and dont have much of an odor..
JerEvil wrote:EndTime wrote:JerEvil wrote:EndTime wrote:Holy-diver wrote:what grits should i buy, im planning on using an oil based stain and i was thinking down to like 200, but whats a good progression?
Awesome man! Thanks.
So again, DO NOT pop the grain with water, just use my orbital sander with 150 then 180 then 220, then apply dye (I bought water based). Let it dry. Get some of the MinWax Polycrilic spray, do 3 or 4 coats and call it done?
Sorry for all the questions on this! No wonder my wife wants to punch me daily!
EndTime wrote:JerEvil wrote:EndTime wrote:JerEvil wrote:EndTime wrote:Holy-diver wrote:what grits should i buy, im planning on using an oil based stain and i was thinking down to like 200, but whats a good progression?
No worries.. Ok, I'll tweak this a bit because you are using a water base dye..
So, to quickly explain first. Just like popping the grain with water raises the wood fibers and makes the wood "rough", so will using a a water base dye.. So as you are applying the dye you'll feel the wood getting rougher.. Which isnt all that big of deal, but you will need to work a little bit during the clear finishing process to get it nice and smooth. So one way to keep the water from the dye from raising the grain too much is TO pop the grain with water, then sand it smooth again. But you wouldnt pop the grain after you final sand.. Basically the more times you pop the grain with water and subsequent sand smooth, the next time water hits the wood there wont be as much grain raise.. SO after you are done dyeing the wood, it'll still have some roughness but not as much..
So a quick step by step.
Sand 120 to 150 with your sander..
-Wet the wood. Let dry
-Resand again. You may have to start at 120 again to knock down all the fibers.. YOu be the judge. But final sand up to 220, even tho I think 180 is ok too with an orbital sander
-Apply dye. You wont do anything to the dye unless you want to do stuff like sand it back and get some different looks.. But if you are happy with how the dye turned out, then move on to
-Spraying first coat of the Polycrylic
-After that first coat, lightly, I mean like feather light sand it with 220 by hand.. You arent doing anything but knocking down any debris at this point..
-Spray 2nd coat
-Repeat with a light sanding by hand with 220
-Spray 3rd coat
-At this point you *should* have enough build up to get a little more aggressive with sanding.. 220 grit with a random orbital sander will definitely leave it smooth as silk, but if you have sprayed really light coats it'll also be easy to sand thru the finish.. You are gonna have to feel that out for yourself. (You may want to put down 3-4 coats with light sanding by hand before you hit it with your sander just to be sure you have enough build up to withstand the palm sander.. Its ok it the coats arent glass smooth after 3-4 coats.. The only time you need it glass is the final coat..)
-Go ahead and spray final coat. If it went well, then you are done..
If its not quite enough build up then keep repeating until you get the look you want.. If you are spraying light coats 5-6 coats of polycrylic wouldnt be that uncommon.
I should also mention you want to clean off the headshell between sanding finish coats with a vacuum/tack cloth..
Devin wrote:I put Tru-Oil on top of that (kinda got a lil too frisky at certain parts and got some drips, but whateva) and then gunstock wax on top of that. It has a real smooth but raw feel/look.
I'll post a NGD thread soon; I'm just about done with it
