Solderless cables for pedal boards...
SexWithRobots
Re: Solderless cables for pedal boards...
Post by SexWithRobots »
Yeah I chnage things around sometimes so its not as clean as it could be but I really recommend the lava cables
RSBro
Post by RSBro »
I had George L's for a long time but switched to the Planet Waves and I like those a lot more. They feel a lot more solid to me and the G.L's were shorting sorta often after I'd have 'em on there a while.
Tell yer Momma I aksed her how she durrin...
The No Limit Honky
Macelind
Post by Macelind »
I have two sets of George Ls too. I had trouble when moving things around with random shorts. They can be a real pain when you have a failure right before a performance because of a pedal swap. The random shorts were one of the contributing factors to me simplifying my pedal board.
Nateispro
Post by Nateispro »
colejustesen wrote:
SexWithRobots wrote:Image
That is what I am talking about! That pedal board is CLEAN!!! Those Lava Cable plugs are such a low profile that they really clean up the board.
Thanks everyone for your input, there has been some great feedback! I really wish the Lava Cable didn't cost as much as it does... I would have to buy 3 kits to make my pedal board clean. The same goes for the Planet Waves, I would need to buy multiple kits to make it work out for me.
The more I think about it, the more I am second guessing myself on getting the solderless kits... I can get those GLS Audio plugs for $30 for 25 plugs, and then I could buy cable of my choice...
this was actually the biggest factor that got me back on buying or making my own cables... they cost of making your own is so much smaller compared to buying a kit. cutting the cable and screwing a plug on.. and in reality.. they probably don't save you much time making them
Kiesel DC800
Ibanez RGD 7 Iron Label
79 Ibanez St-50
80 Ibanez Destroyer II
Kemper
colejustesen
Post by colejustesen »
Thanks for all the information... Sounds like George L and GFS are out of the equation. After getting my new pedal switcher setup today, I need some smaller plugs to get back some real estate on my board... So I am thinking the Lava cables will be what I go with [probably in increments].
Country-Butter
Post by Country-Butter »
Check out Clearfuse connectors buy Mammoth. They have kits with the "Lava" style ends. Also Lava has solderless kits that use other cables that are cheaper.
http://www.mammothelectronics.com/Chand ... fuse15.htm
http://www.lavacable.com/index.php?id=157
These are cheaper and reliable alternatives to the expensive Lava cable.
Rampage wrote:I really don't like you. "Oh hey, I have a sweet Crook tele and a bunch of equally sweet pedals. Feel bad about thine-selves, tone peasants."
My Gear
Fractal Audio Axe Fx 2 Mark II
MFC-101 Mark III
Mission Engineering EP-1 Expression Pedals
EV ELX112P- 2
2010 Crook Custom Tele Blue Paisley with APC Adder/Voodoo TE50
2008 Charvel So Cal in Tangerine with SD Jazz/BKP Holy Diver
Fender MIM Stratocaster
Gravity Picks - Sunrise 1.5mm Mini
colejustesen
Ju5t1n20 wrote:Check out Clearfuse connectors buy Mammoth. They have kits with the "Lava" style ends. Also Lava has solderless kits that use other cables that are cheaper.
DUDE!!! That is what I need right there!!! Thanks :bow:
I didn't realize that Lava Cable made a special plug for Canare GS-6 cable! Those Mammoth ones look great too!
colejustesen
This is what my pedal board looks like with my current cables/plugs and my new switcher... You can see why I want to get a custom kit with small plugs...
That is ugly! I want my board to look clean like SexWithRobots' board!
Matt
Post by Matt »
I have a Lava cable set. While I think they are good, they are also a huge pain to make.
The first time I made them, they didn't work at all. Then I found this video and used that method. Works great, but to be honest, it would have been faster to solder them.
Formerly misle
Music, get some.
Now streaming on Pandora and Spotify.
Buy from Bandcamp, iTunes, Google Play, or Amazon Music!
Echo Collider
colejustesen
Matt wrote:I have a Lava cable set. While I think they are good, they are also a huge pain to make.
It seems like it would take more time to solder the cable to plugs, but I haven't tried any of these systems, so I will have to take your word for it.
At this point, I am needing the smaller plugs. They seem to play much better with my switcher.
You will see what I mean in this video... He uses a plug that looks similar to the Lava Cable plug and it takes up little space. If you compare that to the picture I just posted, you will see that I would love to get some of that space back :D
[video]http://www.youtube.com/watch?v=KuI1SFjT7uk[/video]
Country-Butter
This is my board now. But I want to add a Strymon Möbius and a DMC3-xl to the board. Soon this will be on a pedaltrain.
My Gear
MFC-101 Mark III
EV ELX112P- 2
colejustesen
Ju5t1n20 wrote:This is my board now. But I want to add a Strymon Möbius and a DMC3-xl to the board. Soon this will be on a pedaltrain.
That is a nice looking board! I am not familiar with the Strymon unit or the DMC3-XL [I have no idea what this even is]... I love my pedaltrain; such an easy concept that works great!
Subscribed. :)
primeholy
Post by primeholy »
Damn man, didnt you just get that board?
fuck
neilrocks25
Post by neilrocks25 »
Nateispro wrote:This may just be my experience with them but i have never had good luck with my george L's staying seated in the plug.. It seems like one end always comes un seated every couple weeks or so.. They work great if you don't move your pedals or pedalboard around much but i wouldn't trust them for gigging.. just my two cents :idk:
I have heard this a lot
Country-Butter
Nah. I made this thing about 6 months ago. I have a Salvage flatboard case coming. It will case the pt pro till i get enough money to throw at a Salvage board.
My Gear
MFC-101 Mark III
EV ELX112P- 2
Sex Panther
Post by Sex Panther »
Gigged with the Planet Waves one for years now. No issues...ever.
colejustesen
I decided to order a set of the Gepco XB20UB cable with the Lava CX plugs... I needed the smaller footprint around the ins/outs of my switcher...
If I like them, I will get some more sets [since I will need more than 6 cables].
