...bass traps, cont'd
Work is still going on - I hope to finish up the covers tonight and get them into place in the morning.
The three 'normal' corners all went together similarly. The forth, however, presented a challenge, in that the outlet box was inside the 17" frames I had been building. Rather than make that part or the whole trap smaller (and thereby a little less effective, as well as strange looking), I decided to cut around the box. This requires more framing, and will present a challenge when I start covering the outer frames with material.
Here's what I ended up doing. As you can see, the outlet is still accessible. It'll be a little harder to get at the right sockets when I put the outer frame on, but it's good enough for government work, eh? And yes, I'm fully qualified to speak as a government worker - I work for a public agency, after all
After getting the interior framing completed, my attention turned to the outer frames. These will attach to the interior frames with either screws or velcro. They're going to be covered with acoustically transparent cloth (burlap), so that the bad vibes will go in, and let the rockwool do their job keeping them from coming out. I didn't get any pics of the parts, but you can see how they go together from these pics.
I know I keep raving about the pocket screw jig - these frames went together in about 10 minutes each, including measuring (each is a little different), cutting, drilling the pockets, and assembling.
Then we painted 'em black, so they dont show too much through the burlap. Here's the guy I hired to do most of the labor. You heard it here first - he's gonna rock out the world big-time when he gets older
And yes, I did some of it, too. In addition to being a future rocker and probable engineer, it appears he can take better photos than me.
Here's the 3 'normal' ones
And here's the special one, with the cutout for the electrical box
A lot of the sites I've researched about rockwool have included warnings about fibers in the air causing respiratory and itchiness issues. All the time I've been working with the stuff - putting it in the walls, making cutouts for electrical boxes, and now cutting many triangles and carrying them back and forth from my shop - I've never once had any issues with it. I've been mostly in short sleeves and not wearing a mask, and no problems - not even coughing. This is very different from the regular pink insulation and the blown-in crap that's in my attic - I itch and cough all day long when I get near that stuff. Despite that, I'm sure that some people react different than others, so I figured I'd better do what I can to encapsulate the rockwool, since the burlap I'm using is really porous.
I used lightweight 4 oz polyester batting that I got pretty cheap at Jo Ann Fabric - yes, I did go into that place and buy fabric, and no, they didn't take my man-card.
Wrapped it over, under, and around the sides of the rockwool. You can see it in the pic below. Also note the vertical stops I put in to keep the stuff from falling forward, which I'm sure would ruin someone's day (probably mine
Last night I did some final prep work - covering the last of the rockwool and painting the inside framing black, which will be very close to the burlap. I'm hoping that the white batting will be far enough back that it'll not be seen through the burlap, but I may have to do something about that, too.
As I said, I'm about to start covering frames tonight in the hopes that I can clean all the crud out of the room and start loading in all my gear. Will post pics as soon as I can set my guitar down
