The body has a wenge core with alder body wings, a four way bookmatched Austrailian Lacewood top and back, and is chambered. The neck is a nece pice of lightly figured maple with a Paufero fretboard and position markers on the side of the fingerboard only that are made of abalone, as well as an Ivory nut. Legally obtained of course, before the ban in the US. Nut width is 2.14"/54.55mm. It has a custom made Hipshot bridge which allows the bass to be strung with the ball ends of the strings anchored in the bridge, or strung through the body, and the string spacing at the bridge is 17.25mm. The instrument is also equpiied with Hipshot USA tuners, with a drop tuner on the B string, and Hipshot knobs. The pickups were custom made for me by Kevin Bellar as was the active 18 volt preamp which features a master volume, blend control, bass, mid, treble (+/- 25db), a midrange frequency select switch, and a push/pull swtch on the volume pot that activates a secondary EQ circuit in the preamp (inside the control cavity) that is currently adjusted for slap style playing.
The instrument does not have a case. Never did. I can have one custom made by G & G Custom Cases in Los Angeles if the buyer wishes, and will offer it at my actual OEM cost, or, it can be shipped, well protected and packed very well of course, in a gig bag.
I will edit this post tomorrow after I can get an accurate weight for you. I will also see if I can get a few more "glamour shots" of the instrument to post. For now, here is what I have. I also have some progress pics of the build that I will happily make available to the buyer. I do offer local pickup in Southern California, and for payment, I accept cash (if you're picking it up), PayPal, or bank wire transfer.
Price is $5000.00
