Latest Build . Cameron CCV Based Build
Guitar by my friend Brian, who was playing a Tom Anderson Classic T (tele) with a Floyd Rose. The pickup with the M series which are mini humbuckers with single coil voicing. Brian likes his mids So while maybe not ideal for the metalheads, the amp still got plenty nasty. Lots of different tones, so check them out
Channel 2 clips
[video]https://youtu.be/lXPTAb079XE[/video]
[video]https://youtu.be/V0umaNbNp9E[/video]
Channel 2 demonstrating how well guitar cleans up and responds to the volume knob
[video]https://youtu.be/y8wPT_AdKxo[/video]
[video]https://youtu.be/ZJ7Vl3Fb25o[/video]
Channel 1 Gain . Surprising tone from the "Clean" channel
[video]https://youtu.be/5zh7QOKWA2Y[/video]
Channel 2 clips
BE-100 Clone
Cameron CCV Clone
Single Channel CCV Clone
Mojo 4x12 2/G12H-30s & V30s
Ted Stevenson Pop Classic
USACG SuperStrat
BE-100 Clone
Cameron CCV Clone
USACG SuperStrat
Re: Latest Build . Cameron CCV Based Build
WOW! That amp sound killer!!!
...and your boy, Brian is an ass kicking guitarist!
Can´t but agree.
Nice job!
Nice job!
- newholland
that sounds loverly and the test driver is definitely killin' it.
but i gotta ask... what in the hell are all the knobs for?! i can't even imagine balancing that much data without imminent head assplosion...
newholland wrote:that sounds loverly and the test driver is definitely killin' it.
What? Only 14 knobs and 9 switches not counting Power and Standby
Basically 2 channels:
Channel 1
Gain, Treble, Middle, Bass, Master
3-way Gain Style switch and 3 - Way Bright Swith
Channel 2:
Gain 1, Gain 2, Treble, Middle, Bass, Master, Solo
3- way gain structure, 3- way Bright Switch under each gain, 3-Way Gain Style switch under both the Master and Solo
So, basically although you have a shared tonestack for channel 2, you can have different volume and gain settings when you kick in for solos.
Global Settings
Presence, Punch (Depth), and Hi/Lo power on the back
3-way Dark switch on the presence, 3-way voicing on the punch, and the hi/ow lets you choose between 460v or 540v voltage
DC Heaters, Teflon Coated Wire, 2 button footswitch, and Metro Zero-loss effects loop
BE-100 Clone
Cameron CCV Clone
USACG SuperStrat
BE-100 Clone
Cameron CCV Clone
USACG SuperStrat
Damn dude, this is incredible. Is the loop footswitchable?
GuitarBilly wrote:Damn dude, this is incredible. Is the loop footswitchable?
On this build, no, just a switch for channels and another for the Solo/Boost
BE-100 Clone
Cameron CCV Clone
USACG SuperStrat
BE-100 Clone
Cameron CCV Clone
USACG SuperStrat
- Registered Member
I was getting dizzy looking at all the work you had to do ! Looks killer ! Sounds amazing as well !
All of your amp builds are boner inducing. No need for Viagra when you have sonic perfection at your fingertips. The build quality looks like it's top shelf as well. You should be proud, sir.
Amps: 5150 (w/bias mod), 5150 II, PRS MT-15, FJA PV XXX, Framus Dragon, FJA PV Penta, PV Rockmaster-->Marshall 9100, PV Ultra 120
Cabs: 3 Marshall 1960B, Laney GH412, Avatar 2x15, PV XXX 4x12, Bogner OS 2x12.
MikeO wrote:All of your amp builds are boner inducing. No need for Viagra when you have sonic perfection at your fingertips. The build quality looks like it's top shelf as well. You should be proud, sir.
Thank you sir!
BE-100 Clone
Cameron CCV Clone
USACG SuperStrat
BE-100 Clone
Cameron CCV Clone
USACG SuperStrat
That looks and sounds fantastic!!
That does NOT look like an easy build
Also, mad props to the player for busting out Pat Travers' Snortin Whiskey at the end of the last vid
Devin wrote:That looks and sounds fantastic!!
Alot harder than my single channel version. The single channel version took about a week once all parts were in.
BE-100 Clone
Cameron CCV Clone
USACG SuperStrat
BE-100 Clone
Cameron CCV Clone
USACG SuperStrat
