Bargain condenser mic questions
newholland
Re: Bargain condenser mic questions
Post by newholland »
Reverse Entropy wrote:
newholland wrote:i will say absolutely, that given a stable, constant phantom voltage, and not super high input impedance input load, that a LOT of mics that i thought were meh turned out to be WAY better than i thought they were for years, and a lot of my cheapie performers got way better by leaps and bounds when i plugged them into single power supply devices with lower loads. less expensive interfaces and mixers shoot for the 'average'.. and to my ears, it's pretty far off with a 3-5kOhm input- where dropping it to 500 Ohms makes a MONGO difference over the entire spectrum to my ears. used to be (pre-mackie days) that your average was probably 3-500, but for whatever reason the VLZ pushed it higher, and things got crispy.. :D maybe made sense in the analog era... but gah.. it's harsh for digital.
Oof. I'm sloppy, I wasn't thinking about impedance matching yet.
Question, and I'm not being a picky-ass I just want to clarify so I understand you properly...
Lower resistance (in AC, impedance) electrically loads a circuit more heavily (high current, low voltage drop) and high impedance the opposite (low current through, high voltage shows across the inputs). Did you reverse this when you typed that, or am I missing something ? [it's been a long while since my power circuits courses...]
Looking at my various few options in preamps / mixers for an upcoming mobile project, the "low" impedance inputs are all in the 3k to 5k ohm range you mention. Looks like I'm setting myself up to fail unless I find a lower impedance preamp for the mikes.
Perhaps a Presonus Blue Tube DP ? Any other suggestions ? From the discussions here I suspect I'll end up using a pair of M179s or KSM27s.
i can't necessarily speak to the electrical aspects-- but i do know that when you drop the impedance of a mic input circuit, you alter the frequency response. if you're shooting for maximum frequency response, the rule of thumb is something like 10:1-- so a 150 ohm mic should see 1500 ohms at the pre. but seriously.. who records every source 100% full frequency? oh yeah.. nobody. :D
when you drop input impedance, the mic'll focus more on midrange frequencies. things loosen up, you lose a little top, and a little bottom, but things can get pretty technicolor in the PERTINENT frequencies for most music.
this isn't to say that one can't make good recordings with higher impedance mic pres-- only to say that some of the things that make modern recordings sound dry and hifi is this fact, and it's one of the reason i think that a lotta people think mics sound bland and whitewashed comparatively. i'm certainly no believer in the DC to light frequency response.. it's just not necessary, and i think it sounds pretty bland too. but i've sure recorded a lot through mackies and done okay.. i'm just happier with lower input impedance preamps and have a couple. i still record drums through high z inputs because they give what they've got over a broad range-- and i tend to not close mic them- so i'm looking for an overall picture of the kit with less mics. i'll often record guitars high z, because they're not super fussy, but if it's one track at a time.. i'll use lower. bass? depends.. but either works well- depends on the tone. vocals? i usually go for a lower value, absolutely. other instruments too-- but by and large, i prefer going in at 3-500 ohms.. and again... totally depends on the mic and sound.
there's not really rules-- but i really more wanted to make mention of the fact that some of these less pricy mics can sound really good and it isn't just the mic that bungs things up to sound meh! they ain't all fantastic.. but some of them are really really good for what you pay for them compared to what you'd get 15 years ago for 10x the price.
wrt what pre? well.. a lotta guys sorta start their missions with the art pro mpa2. i've had no particular love for any presonus gear, tbh-- and i do know the ART unit HAS adjustable z. so does the focusrite twintrak pro (i have one- works fine, but nuttin' fancy). but my focusrite interface ALSO has low z input (drops to 300ohm) on one channel. not well advertised.. but it does. for on the cheap--either of those two units'll give you some flexibility though, and at least let you see what happens-- and seriously-- just listening to what happens will blow your mind. it's not always subtle. :D
Reverse Entropy
Post by Reverse Entropy »
Gotcha, thanks. If we plug in some values here : http://www.muzique.com/schem/filter.htm
Like 150 for the resistance and .1uF for the capacitance, we can pretend to see what a preamp will do. With those numbers, stuff from 10.6 kHz and up will be partly shunted to ground (6dB per octave) instead of going through our preamp. If we just change 150 to 1500, the shunting starts at 1060 Hz instead (same 6dB per octave).
Interesting, thanks.
“Never attribute to malice that which can be adequately explained by stupidity."(Hanlon's Razor)
"rock enough that I don't drown in ... jazz ennui" - draelyc
"...you realize that absolutely nothing happens when you get butthurt, right?
You know you're not going to go home and immediately have cancer, right?" - Steinmetzify
newholland
Reverse Entropy wrote:Gotcha, thanks. If we plug in some values here : http://www.muzique.com/schem/filter.htm
yeah-- the math is neat-- sonically, it kinda manifests maybe a bit differently, which i think has more to do with the actual acoustic properties of the diaphragm of a mic, and i dunno if they can add that in to the equation mathematically. i mean- it's a model.. so it's not gonna be perfect-- and it doesn't really sound like there's LESS treble-- it actually seems to act more, to my ears, like a presence circuit does. with higher loading-- the mic just sounds more flat and stable-- but less musical. with less- it breathes more, and sounds more like it sounds-- but that being said-- it sounds less exact. i'm a sucker for less exact i guess :D
I got the AKG P220 today , the seller sent me the black one and not the blue one , no biggie . I like the mic it's different then what I already have so that's cool . it has a lot of sound from the back , I could hear screaming kids all the way down the street and a lot of outside noise but I was able to hit record at a quiet moment . I just tracked some goofy shit for the Dad rock drum jam . I mic'd a mando and a 12 string acoustic . The mic has a ton of gain so it was easy getting a good level . it cost about $125 @ the bay .Check it
https://soundcloud.com/fretlessjamz/turbopablos-dad-jam
