Incoming NAD
Incoming NAD
So last night I found a good deal on a Mojotone Superbass. It was modded with a master volume and a switch that allows you to go from the 2203 circuit to the Plexi bright channel. So technically it's not a Superbass anymore lol but still an interesting amp. I plan to install a Metro loop and maybe JEL mod the 2203 side, to have the ultimate Marshall style amp. But maybe I will do the loop only. I need to listen to the circuit first. It Should be here later this week and I will update the thread. :thu:
Re: Incoming NAD
Ya that’s gonna be awesome!
spawnofthesith
Re: Incoming NAD
Post by spawnofthesith »
:love:
I give it 5 clips, 2 gigs, and 3 weeks :lol:
maggotspawn
Re: Incoming NAD
Post by maggotspawn »
Sounds like a killer map. Congrats.
Re: Incoming NAD
It arrived today:
The good: the amp looks clean and sounds good. The Plexi/2203 preamp mod is very interesting. With the switch set to 2203 mode, it sounds/works like a 2203 should. On Plexi mode, it's the bright channel of the 1959SLP, but with a master volume. So if you set the master on ten and bring the volume up with the Gain knob, it works like a NVM plexi should. But you can also use all sorts of different combinations between the volume/gain anmd get a whole rang of cleaner tones.
Now the bad: the amp's volume is very quiet overall. Certainly not what I'd expect from a 100w Marshall. Actually the 20w Plexi I had was way louder. Even on 5w mode it way way louder. So there is definitely a problem there. Any idea of what it could be? I already ruled tubes by trying a whole different set to no avail. The tone is good and there is no hum or any other apparently problem, just super low output.
I emailed the seller and I am waiting for a reply. I like the amp so hopefully we can work something out and get it repaired. Or it will go back :( To be continued....
Re: Incoming NAD
Looks great but yeah a 100 watt tube Marshall should be painful af with the master bypassed.
Is there a PPiMV or something not in plain sight?
Re: Incoming NAD
Dave wrote:Looks great but yeah a 100 watt tube Marshall should be painful af with the master bypassed.
nothing that I can see. I will see if the seller pays for my tech to look at it. Something is definitely not right.
Re: Incoming NAD
Do you know if the amp ever operated normal/loudly?
How old was the kit?
Re: Incoming NAD
Tortuga wrote:Do you know if the amp ever operated normal/loudly?
No idea, I just got it 2 hours ago. I am waiting for the seller to reply.
spawnofthesith
Re: Incoming NAD
:( hope all is resolved
Chris Z
Re: Incoming NAD
Post by Chris Z »
Is there a loop volume control?
Re: Incoming NAD
Chris Z wrote:Is there a loop volume control?
There is no loop at all. I bought a Mojotone loop but I haven't installed it yet. I will take it to my tech and have him figure it out and install the loop. The seller offered me $300 back so that should cover the cost of the repair.
rock flag and eagle
Re: Incoming NAD
Post by rock flag and eagle »
that's cool of him, hopefully it's a cheap easy fix, sweet looking amp
NinjaRaf
Re: Incoming NAD
Post by NinjaRaf »
Damn. Wonder if he knew it had some kind of issue...Like that first ALX EMG that I bought that the dude clearly knew he was selling something broken.
EVH
Mesa
Bauer
Guiterrorist
Pakistani Right Hand of Doom
Pesobag
Mike Oxhuge
Re: Incoming NAD
Post by Mike Oxhuge »
The only time I had that problem was a Crate Blue Voodoo with a failing OT. Hopefully it's something simpler.
Peavey XXX Head
Henning Bottle Rocket Preamp
Carvin MTS3212 Combo
80's Washburn Scavenger Bass
Boss GT1000
Re: Incoming NAD
NinjaRaf wrote:Damn. Wonder if he knew it had some kind of issue...Like that first ALX EMG that I bought that the dude clearly knew he was selling something broken.
yeah who knows. The guy seems nice so I am giving him the benefit of the doubt.
Mike Oxhuge wrote:The only time I had that problem was a Crate Blue Voodoo with a failing OT. Hopefully it's something simpler.
Yeah I hope it is simple. The amp sounds like it should, just not a lot of volume.
Mike Oxhuge
Re: Incoming NAD
At least it doesn't sound like a Blue Voodoo!
Peavey XXX Head
Boss GT1000
boris the blade
Re: Incoming NAD
Post by boris the blade »
Re: Incoming NAD
Yeah it's disappointing. I'll take it to my tech this week and hopefully this will be an inexpensive fix. I'm just waiting my my effects loop to get here so my tech can do all work in one shot.
Re: Incoming NAD
Post by Marc G »
is it so quiet that you can't use it live? because.... this could be a blessing in disguise.... so many people chase the cranked Marshall sound but not at an ear splitting volume level... you may have lucked out with this amp
Re: Incoming NAD
Marc G wrote:is it so quiet that you can't use it live? because.... this could be a blessing in disguise.... so many people chase the cranked Marshall sound but not at an ear splitting volume level... you may have lucked out with this amp
I think I could use it live with the volume all the way up. It's probably loud enough that way, which yeah, it is actually pretty cool lol
But I'm sure the volume issue is a symptom of an internal problem, so I don't want to keep using it until I know what the problem is.
Re: Incoming NAD
Post by Marc G »
ok... yeah... if you have to crank it to 11 to use it live then something is really wrong somewhere....
Re: Incoming NAD
Imagine running a gig at full tilt, and you bump the amp just right and the proper connection is made. The amp decimates the entire venue. :lol:
Re: Incoming NAD
Post by Marc G »
Dave wrote:Imagine running a gig at full tilt, and you bump the amp just right and the proper connection is made. The amp decimates the entire venue. :lol:
:rawk: :rawk: :rawk: :rawk: :rawk: :rawk: :rawk: :beavis: :beavis: :beavis: :beavis: :beavis:
Re: Incoming NAD
That is the kind of issue I WANT to have :lol:
